Some Wiring Questions
JiB
JiB Posts: 10
Just got a set of monitor 40's for my rear speakers! Now I need some new wire to set them up, I was thinking of getting 12 gauge and banana plugs. Is that a heavy enough gauge to run 25 feet? And would tinning the ends with the banana plugs be any good? Also, is Bi-wiring worth it?
Thanks,
JiB
Reciever: Yamaha RX-V667
Centre: Polk Audio CS2 (Comming Soon)
Fronts: Polk Audio Monitor 70
Rears: Polk Audio Monitor 40
Wire: 10 Gauge
Nanners: Nakamichi Screw Type
  • John K.
    John K. Posts: 822
    edited September 2010
    JiB, welcome to Club Polk. The outstanding resource available to us on speaker wire in general, and gauge suggestions in particular, is this explanation of the facts by a veteran audio professional, which has helped countless newcomers over the past few years to avoid the wire scams which pollute our hobby. As you'll note, even 16ga would be fine for your use and there's no good reason to get a heavier, harder to handle wire. Tinning the ends isn't necessary.
    As to bi-wiring(aka "buy-wiring"), no there's no significant electrical difference created by that and no audible improvement is available in reality.
  • JiB
    JiB Posts: 10
    Thanks for all the info, that lowered my budget quite a bit.
    Wire: 10 Gauge
    F1nut Posts: 52,406
    JiB, that advice given to you by john k. is about as bad as it comes. You would do well to ignore it and that link he posted.
    Go with the 12 gauge.
  • JiB
    JiB Posts: 10
    Wire: 10 Gauge
  • fishbones
    fishbones Posts: 947
    In the end...everything matters. Don't skimp...especially on long runs.
  • decal
    decal Posts: 3,205
    Go to wally world or home depot to but that type wire.Why pay shipping and have to wait for it?
  • Knucklehead
    Knucklehead Posts: 3,602
    decal wrote: »
    Not something that I would use in my modest system nor reccomend to anyone else.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • JiB
    JiB Posts: 10
    decal wrote: »
    I have to pay shipping on the banana plugs anyway, it will only be a few bucks more to add the speaker wire.
    Wire: 10 Gauge
  • Outfitter03
    Outfitter03 Posts: 563
    Here are some links to products:
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2747&seq=1&format=2
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=100-024
    http://www.bluejeanscable.com/store/speaker/index.htm
    Banana Plugs:
    http://www.soniccraft.com/products/connections/banana/vampire_b12.htm
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=091-330
    The highest quality wire in the above links is listed last from Blue Jeans Cable. If you are interested in doing it once and can afford the cost the Canare 4s11 is really good cable. I currently have 45 foot runs to my rears using the Monoprice 12 gauge and it works pretty well. I am pushing a lot of watts though as these are the only speakers hooked to my AVR. I have this wire going to my surrounds also, but will be upgrading to the Canare 4s11 in the next couple of months.
    There are a lot of bananas to choose from. The vampires I listed are solder/crimp connectors. The Daytons are two way clamping and are solidly made. Both of these are not pure copper, which is more expensive and higher quality.
    There are several threads, one about two months ago with a lot of information and opinions on banana plugs. I bought some from monoprice and I didn't really like them. My opinion. Good luck to you and have fun with your new system.
  • decal
    decal Posts: 3,205
    JiB wrote: »
    You can buy banana plugs at radio shack or best buy.
  • JiB
    JiB Posts: 10
    Wire: 10 Gauge
  • sm88
    sm88 Posts: 353
    Those locking binding posts are wonderful! You had me worried with those links, there are LOTS of knockoffs on the bay, but they come from 'Hong Kong', you can usually filter them out by searching for only North America.
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
  • JiB
    JiB Posts: 10
    sm88 wrote: »
    I even hate ordering stuff from the US, they always want to charge duty and brokerage and extra taxes. I would never order anything from overseas, not worth the shipping.
    Wire: 10 Gauge
  • sm88
    sm88 Posts: 353
    JiB wrote: »
    As far as I can tell, shipping is subsidized in Hong Kong so it is very cheap to air mail things out. But fakes are rampant, and they are very good fakes.
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited October 2010
    hi , I've thought that I read here that you can run a jumper from left spk to right and then one to the amp . This if I heard it right I totally do not understand.How would both sets of spks get pwr.....lw
    keep in mind I still marvel how a refrigerater works...
    H/T---
    TosibaAU37
    Yamaharx-v665
    Klipsch 500 set w/pwrsub
    Denon1910ci-cdp
    Yamaha yds11 dock
    -2-ch
    Adcomgfa555
    Onkyo-P301-pre
    Infinitys sm112s
    Denon1910ci
    Dual1219 turntable
