TSi 400s-will I need a sub?
Hi all. This is my first post. Currently I have a Harman Kardon 2 ch stereo reciever-75X2 RMS with a pair of Polk T15s and Infinity 10" 150 watt sub. I plan on getting a pair of TSi400s and more power-maybe about 150 per speaker. Will the sub still be needed? With that much power going to the 400s, will the sub even add anything to the system? Thanks in advance.
Bill
Bill
Post edited by wild-bill on
Yes,except I'd upgrade the sub, the polk 505 would go nicely and is fairly cheap.HT SYSTEM-
lsi 9's -
I have the monitor 60's which are pretty similar. I prefer to have a sub when i listen to music in 2 channel mode, but they don't sound too bad without one. I think it's a matter of personal preferance but i like to have more bass. I use the 505 and it sounds great.
I have the TSi400's and got the PSW505 as well. I also have a CS20 center. I am nothing but impressed with the results. I have not listened to the 400's without the sub but for under $250 getting the 505 to compliment them is a no-brainer.
Good luck! -
Thanks for the help. I looked at the 505 sub online-nice. But is there a Polk speaker that will make me forget about a sub-what about the TSi500 or RTi A7?
The TSI500s are pretty good in the bass dept, but not amazing. I have the 500s in a 15x12 room, hard wood floors, running 135w off a stereo amp.
Once they are broken in (took about two weeks for me), the bass definately dropped a little bit. Does very well for typical music, bass solos are quite crisp. However if you are into much bass heavy music (bass mechanic, electronic) or movies you'll wish you had a sub.
Really does depend on your tastes. Hard to get the infrasonics a dedicated sub will get you, unless you are running some monster towers..Components in The Rack:
Yamaha RX-V765 7.1 AVR
Sony TA-N511 (from 1065 to sub)
Xbox One
MA PD-915R Power Strip
Monster HTS-1650
Speakers:
L/R- Polk TSI-500 Cherry, 12awg in place of jumpers
C- Polk CS20 Cherry
SRs- Polk TSI-100 Cherry
Sub- Kicker S12L5, vented box
Display:
Sony VPH-1252Q
75" 16:9 DIY BO Cloth Screen
Not running:
Crown Straight Line Two
Crown Power Line Four
Pioneer PD-F908
Fender BXR Dual Bass 400
Pioneer BDP-51 -
I have to agree with this man. I have the PSi500s too and opted for 2 PSW111 as I couldnt get any of the better subs over here. I do love a good boom when watching the movies.
From what I hear the PSW505 is a good sub for the money.Home System
Panasonic Viera 65"
Yamaha 3030
Fronts Yamaha NS777s
Presence fronts Yamaha NS333
Centre Yamaha
Surrounds TSi500
Surround Rears TSi200
Rear Presence TSi200
MicroPro 4000 front
Yamaha something to the rear
Left and Right subs PSW111 x2
Car
Kenwood double din touch screen
Focal utopia fronts
Focal K series 5.25" rears
Focal 13.5" subs in the rear
Focal FPS2300RX for the subs with 2 hi caps
Focal FP 2.150 for fronts
Focal FP 2.150 for rears -
Get the sub. Polk TSI series speakers produce more bass as the drivers increase along with the cabinet volume. But, in reality, Polk bass is a tight focused bass--not a thunderous HT bass. So yes, you'll need a sub. The PSW505 is a good budget sub with 300 watts and a 28hz bottom end adequate for movies in small to medium sized room.
