Dampening Material
TrashyTrucker
Hey all,
Yet more question(s)...
Seen here in Larry's ring post
http://www.polkaudio.com/forums/showthread.php?t=102023
I noticed some fabric or sound dampening material on the sidewalls of his speaker review post please (scroll down to 9th pic) What is that? I havent begun the task of my upgrades yet and wanted to get all information before I start!
1)what is that? Is it stock?
2)Isnt there some sound dampening paint? Thought I might of read that here somewhere?
3)Where do you order this paint?
4)Is it necessary? I have already climbed in this deep thus far!
Sorry for the questions... but what do you expect from a Newb?
OK...let the bashing begin!
Matt
Matt
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
Rotel RCD 1520 cdp
biamped to:
TOOLFORLIFEFAN wrote: »It's BlackHole on the back walls and Sound Barrier on the side walls. You can buy it at parts express and sonicraft.
It does a fantastic job on the highs but I did not like it on the lows.
I kept it in my 1C's and took it out of my 1.2tl's.
Try it at your own risk with that said I say you do all but this JMHO.
Thanks Larry,
And I got the complete set of (+tweets brackets) rings today, Thanks! Fantastic job! Will install them real soon, I am still waiting on the dynamat and Sonicaps,mills etc... Hope 18" x 32" (4 sq. ft.) Dynamat will be enough to do the
3.1's?
If not I can go to a local retailer and pay 4x's as much LOL. :rolleyes:
Thanks to you all,
MattIntegra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
