rtia7 worth 200 more than the rtia5
lriker
lriker Posts: 64
edited September 2010 in Speakers
Just deciding on which fronts I want to go with my rtia1s. The rtia9s are way too much for me so not an option. I listen to 90 percent ht so between the rtia7s or the rtia5s. Not planning on getting a sub for quite awhile so my question is if the rtia7s as a pair are worth the extra 200s over a pair of the rtia5s? Thanks
Post edited by lriker on
  • packetjones
    packetjones Posts: 1,059
    Most people recommend the A5's over the 7's. General consensus is that they 5's and a good sub are better for HT. The 7's without a sub may be ok depending on the amp that you have pushing them. What Amp are you going to be using.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • lriker
    lriker Posts: 64
    dont have any amp yet. I bought a used pioneer 1018 that is rated at 120 per channel and has preouts so I could get an amp later. Guessing the 200 would be better spent on other items? If I did a no no according to most here and did not get a subwoofer, would the 5s still be better than the 7s? I say no sub because room is 10x13 and even with the rtia1s as my fronts and monitor 30s as the rears, the bass for my ears is quite fine.
  • kevhed72
    kevhed72 Posts: 5,191
    Maybe keep an eye on Polk Direct if a pair of A9s come up for bid:
    http://stores.ebay.com/Polk-Audio-Direct/_i.html?_nkw=A9&_sid=686154689
  • PrazVT
    PrazVT Posts: 1,607
    You mentioned:
    - you're fine w/ the amount of bass you're hearing now
    - 90% HT usage (movies, tv, presumably)
    If you're happy with the amount of bass you have right now, and you're mostly just watching movies / tv / etc., then the A5s are probably fine. I assume that recommendation is due to the extra midrange driver.
    Plus they may be more easily driven by an AVR alone than the A7s and A9s. Sufficiently powered, though, the A7s sound great to me for music and movies. Caveat here is that you need dedicated power to get the most out of them, which = more $$.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Fongolio
    Fongolio Posts: 3,516
    The RTiA7's can push some serious bass when given ample dedicated power. When I used mine as fronts for music and through an AVR they were good but not great. However, when I put them with a Carver TFM-25 it was a holy $h!t moment. Big articulated and very controlled bass. Did not need a sub when running through the Carver. Totally needed a sub when running through an AVR.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • leroyjr1
    leroyjr1 Posts: 8,785
    A5's work great for HT and they're very efficient.
