Monitor 50 vs 60 for HT?
Can anyone help me quantify the difference between the Monitor 50 vs Monitor 60 when used for HT?
This would be with a CS1 center, Onkyo 606 and 14x20 room.
Any difference in clarity at low volumes?
Thanks in advance.
Thanks in advance.
Post edited by blah325 on
Obviously the 60's have another driver. I would recommend the 60's myself. To be honest I have not heard wither of the speakers but the 60's get a lot of praise around here. There are not as many people with the 50's.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Larger is always (almost) better IMHO.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
The main difference you will hear is in two channel. You can get by with M50s if you use a CS2 for your center and get a good sub to handle everything below 80hz?
By getting the larger center you address the most important surround channel--which carries over 50 percent of your sound in HT! And the sub picks up what would normally be gained by a move to the M60s if it's tight and powerful enough.
