Pictures of monitor series II??
Anyone have any high quality pictures of the floorstanding Monitor series II? I'm trying to evaluate aesthetics against the TSi series...
Post edited by blah325 on
Newegg.
Google image search. The Monitor series gives up some looks to the TSi line IMO. The piano black tops and the colormatched fronts on the TSi's are far better looking, but the internals are very similar. Depends on how much you value aesthetics.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
http://www.polkaudio.com/homeaudio/products/recent/monitor70/
http://www.polkaudio.com/homeaudio/tsi/index.php?s=tsi500Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables -
He wants to see pictures of the series TWO Monitors, domfalne, not the series ONE Monitors.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
As said above....check out newegg. Basically the only real differences between the original Monitors and the II series is that the II seems to use TSI colored drivers and has a black front baffle instead of a silver one.
Those two differences do make the II series look a bit more updated than the silver faced Monitors....but I'd still give the aesthetic nod to the TSIs as domflame does above!
Nonetheless the II are a solid 'second place'.
