Wiring Atrium 65SDIs for dual mono?
TheWind
TheWind Posts: 6
I have a stereo receiver with its Zone 2 outputs feeding a Denon POA-8200 amplifier. The amp has A and B speaker outs and I want to use them to power four outdoor speakers.
On “A” I will put a pair of Polk Atrium 60s. They are normal 8 ohm speakers so, no problem.
On “B” I want to put a pair of Polk Atrium 65SDIs. The “SDI” means each speaker has a “Single/Dual Input Switch” which, with its dual tweeters, allows a choice between normal stereo connection or the connection of both the right and the left speaker wire to a single speaker. (Thus, the moniker “single speaker stereo”. – I know, I know…) Because of the where the “B” speakers will be located, I want them to be in mono, (or “dual single speaker stereo" ?); not stereo. How would I wire these 65SDIs so that the both the “B” right and “B” left speaker wires go to both of the 65SDIs? Is this possible or, is there some other wiring that would result in all the sound coming out of each 65SDI?
Thanks for any advice.
Dave
