Infinity Kappa Five
![PerfectCreature](https://w3.vanillicon.com/32fb00315e72dc672b84baebf861616e_100.png)
PerfectCreature
Would this amp be a better amp than the two I have now.
I can pick it up for fairly cheap.
Curious if it would be an improvement or a waste of time over my
JBL GTO 3501. Kciker ZX 200.1
Thanks.
Thanks.
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Post edited by PerfectCreature on
Are those the only amps you have? If so, then yes. You don't have any full range amps, and the infinity will provide power to your components.
But if you have a full range amp, then buying the infinity kappa five would be a waste of time unless you have space issues. The difference between 300 and 360 watts of sub power is nominal, you won't benefit any perceivable gain from that little of a power boost. -
My bad, my amp is a Zx 200.4.
Yeah, that is what I thought I was just curious. Thanks.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
Sounds good to me. I will keep what I have. Thanks.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
