sacd affordable?
scottyboy76
scottyboy76 Posts: 2,905
edited September 2010 in Music & Movies
now that im slowly creeping into a better setup, would i be able to tell a difference between a very nice older denon cd and a sacd.
because of limited income, the cost of used player would be a factor, the cost of individual cds a little less so, because we will probably just buy a relatively few of our albums over time.
anyone with experience with both please let me know the cost benefit ratioin your opinion.
thanks
humpty dumpty was pushed
Post edited by scottyboy76 on
    Tony M Posts: 11,599
    You will love SACD over any regular cd player almost...
    It's a part of the audio world SONY just doesn't care about a whole lot but they do plan on making alot more discs it seems.
    I only own one SACD but will buy alot more in the future I'm sure.
    The players $ has come down alot so the only cost is paying a little more for the discs but BELIEVE me , it's worth everything extra they charge.
  • tcrossma
    tcrossma Posts: 1,301
    On my system, SACD was nice and all (2-channel only for me btw), but in all honestly my Classe redbook player sounds better on most regular CD's than my Denon 3910 SACD player did on most 2-channel SACD's. At one point I did try a few 5.1 SACD's and they were nice, but it just wasn't my thing.
    As with any format, there are some very good sounding SACD's and some not-so-good sounding SACD. And there's also some great sounding redbook CD's, and some not-go-good sounding ones. So from my point of view, SACD is fine and all, but it's not the best thing since sliced bread or anything.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • scottyboy76
    two experiences, different opinions. might have to try scouring cl for a deal on a player. although probably not as ubiquitous as av receivers speakers and such.
    go the bargain route to see if its my thing.
    F1nut Posts: 51,713
    Garbage in, garbage out applies to all sources.
  • HHStuart
    HHStuart Posts: 263
    I got into SACD's late - didn't buy any until December of 2009. I am now up to 137 of them because I found I really liked some of them. Bargain route worked fine for me. That allowed me to experience some I would not have tried otherwise. However, having said that, the order in which I like the SACD is usually 1) the piece itself, 2) the performer or composer and lastly whether it is SACD or not. I do find that I like some of the Multi Channel ones a lot and they are a definite plus for some recordings. About half of my SACD's are classical, one fourth are jazz and the rest are popular/rock. Unfortunately, a lot of good ones, especially the popular/rock, are out of print. My average for the classical ones is about $9 each and for the rest about $7.50 each. I buy only SACD's now.
    Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
    Subwoofer - Epik Legend
    Receiver (as Preamp) - Sony STR-DA3400 ES
    Amplifier - Outlaw 7125
    Television - 58" Samsung Plasma PN58B860
    Blu Ray - OPPO BDP 83
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    true dat. well, the disc in the tray not included.
    for a budget rig a Denon 2900/3910 and a MF tube buffer produced a rather pleasing sound for me.
    Edit....for SACD I am saying for....redbook, do the mod as not so hot.
    RT1
    My Ultech UCD-100 CD player plays CDs the best. then the Denon (I think) 2800 DVD CD player second.
    My Pioneer SACD CD DVD player does pretty well w/cds and dvds but it seems neutral but accurate at the same time.The one Carpenters SACD I own sounds like the people are really in my room. A friend of mine who is a drummer thought he could tell the type of sticks he was hearing in the recording as they or one hit the rim of the drum.
    I didn't know there were some bad SACDs. I'll check online and search well before I pay for future ones.Thanks
