What crossovers are these?
thejck
thejck Posts: 849
edited September 2010 in Vintage Speakers
What crossovers are these? I was under the impression that they were 1.2's because they had the pin/blade cable but the crossovers look like the originals unless I am mistaken.
Post edited by thejck on
  • thejck
    thejck Posts: 849
    My crossover look like this and they also have the pin/blade cable
    Toolfan66 Posts: 18,166
    They are the SDA SRS originals..
  • thejck
    thejck Posts: 849
    With the pin/blade connectors? I guess so much for that foolproof method of checking.
    That is odd, but could be a later model when they went to change things or someone changed them out.. I have 2 sets of them here.
    Tony M Posts: 11,691
    The originals came with those massive caps?
  • michaeljhsda2
    michaeljhsda2 Posts: 2,202
    thejck wrote: »
    Did those come out of the 1.2's that you just bought? Seems very unlikely they are as you have a pin/blade IC. Those are from the original SRS (blade/blade) not 1.2's IMO.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    thejck wrote: »
    That's very similar to what my 1.2TL's looked like before I upgraded the xovers (not a 1.2 to 1.2 TL conversion btw).
    SDA SRS 2.3TL's
    SDA 2B TL's
  • thejck
    thejck Posts: 849
    Those are not the orginal caps. They have been upgraded by Maybe Ben. That is the set that my neighbor picked up from Nekashi
  • thejck
    thejck Posts: 849
    Those are my neighbors. He also has the pin/blade inter. We went over to Oklohoma City to buy them from Nekashi.
    I assumed they were the 1.2 because of the pin blade cable. However when we opened them up we were surprised.
  • michaeljhsda2
    thejck wrote: »
    Surprised is right! Someone did major surgery on your neighbors xovers to make them TL's. On the other hand, converting yours to TL's won't be as involving IMO.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • thejck
    thejck Posts: 849
    Well I knew they were not TL's since they had the rdo194's. However I thought they were at least 1.2's since they had the pin/blade.
  • michaeljhsda2
    Right, they're not 1.2 TL's...very interesting upgrade.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • thejck
    thejck Posts: 849
    Why is it that the original SRS had such hugh crossovers compared to the 1.2's and 1.2 TL's?
    Those are solen caps on the modified crossover and they are hugh
    You "CANNOT" tl the Original SRS's
  • thejck
    thejck Posts: 849
    Yup saw that already.
    Feel really bad for Robert (neighbor) because I was the one that made the assumption that they were 1.2's and never thought to ask what they really were. Even though when I go back and look at the for sale thread there was no mention that they are 1.2's. I guess the pin/blade cable threw me off.
    Feel kinda stupid. I have learned a lot about this speaker in the last 2 months.
    I guess once I get mine up to 1.2 "TL" status he can give them a listen and see what the difference is.
    What should he expect to listen for. I know the originals are said to have more bass. He already has the rdo194 tweeters so that should not make a hugh diff.
    Plus his speakers are 4 ohms and not 6.
