TSi 500 vs. RTi A5
ZackaryJim
ZackaryJim Posts: 18
edited September 2010 in Speakers
Hello everyone. This is my first post, so let the obligatory welcoming ensue. :)
Now that that's out of the way, here's my actual question.
I'm working on finishing building my home theater. You can see what I've got so far in my signature. What I need some input on, though, is choosing some floorstanding speakers to replace my monitor 40s (they're moving to the back for surround). I'm down to two speakers, the TSi500s and the RTi A5s.
My thoughts for the TSi500s:
Pros: almost identical drivers/cab design to the monitor series - good for voice matching/blend, flagship of the TSi line, aesthetically will match my m40s well, slightly lower (38 Hz vs 40 hz -3dB) response
Cons: Lower line than RTis, the cherry veneer is nice, but not 100% convincing
Now the RTi A5s:
Pros: LOVE the real wood finish, "higher" line of speakers, ARC and Powerport venting
Cons: "base" model of RTi, may not blend as well considering notably different driver/cab design, won't aesthetically match monitors but they're so damn pretty who cares? :D
I'm a Best Buy employee so through an accommodation through Polk, the speakers are effectively the same price.
I want to try to get these as soon as possible, so I want to try to stick to the budget these are around. BUT, if I was patient I could step up to the RTi A7s. At that point the TSi/RTi debate would be a no-brainer for me.
Thoughts?
Current HT Setup:
-Panamax M5300-PM line conditioner
-Yamaha RX-A1000 receiver
-RTi A5 fronts
-RTi A4 center
-RTi A1 surrounds, TL-1 series center rear
-SVS PB10-NSD subwoofer
-Behringer FBD calibrated using REW
-12 Auralex 2'x2' SonoFlat absorption panels
-4 Auralex MetroFusor diffusor panels
-Panasonic TC-P50ST30 TV
Post edited by ZackaryJim on
  • Norm Apter
    Norm Apter Posts: 1,036
    edited August 2010
    I didn't see you list of gear when I clicked on your signature but my philosophy toward speakers, which I consider the foundation of one's system, is get the best you can afford and then make changes around that.
    Don't let the fact that Rtia5s are the lowest of their line fool you. Many, though not all here, actually prefer the Rtia5s with a sub to Rtia7s or Rtia9s.
    I'm sure others will chime in but as long as you have the amplification to drive them and a decent sub, Rtia5s all the way!
    2 Ch.
    Parasound Halo A23 Amp
    Parasound Halo P3 Preamp
    Parasound Halo T3 Tuner
    Bada HD22SE tube CD Player
    Magnum Dynalab Signal Sleuth
    Magnum Dynalab ST-2 antenna
    polkaudio Lsi9s (upgraded cross-overs)
    MIT Shotgun S-3 Bi-wire Interface Speaker Cables
    MIT Shotgun S-3 Interconnects (3)
    IegO L70530 Power cords (3)
    HT
    Denon 2808ci AVR
    polkaudio RTi A5s (fronts)
    polkaudio RTi A1s (rears)
    polkaudio Csi A6 (center)
    Signal Cable Ultra Speaker Cables
    Signal Cable Analog II Interconnects
  • bopicasso
    bopicasso Posts: 878
    edited August 2010
    I owned the rti8s which are the model before the Rtia5. I liked them alot. For the same price I would definately go with the rtia5s. Even though they dont timber match with the monitor series, it will be a better speaker for the money.
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • ZackaryJim
    edited August 2010
    Here's the list of gear that should(?) be in my signature.
    Current Audio Setup:
    -Panamax M5300-P line conditioner
    -Pioneer 919AH-K receiver
    -Monitor 40 fronts (bi-amped)
    -CS20 center
    -DefTech ProMonitor 800 surrounds
    -PSW111 subwoofer
    Planned Setup:
    Home Theater Room:
    -TSi 500 OR RTi A5 fronts (opinion? - http://bit.ly/bJ1VXz)
    -CS20 center
    -Monitor 40 surrounds
    -PSW125 subwoofer
    Bedroom:
    -DefTech ProMonitor 800s in stereo
    -PSW111 subwoofer
    -Denon DRA-397 receiver
    Current HT Setup:
    -RTi A5 fronts
    -RTi A4 center
  • bklynNupe
    bklynNupe Posts: 728
    edited August 2010
    Rtia5's are really nice performers when they break in.
    However IMO, you should take the funds that you were considering for the a7's and rolling it into your sub budget. maybe you can get a deal on something used?
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • ZackaryJim
    edited August 2010
    Norm Apter wrote: »
    Thanks a ton for the input. I've got a PSW111 right now, which wouldn't have been my first choice, but I got it for free from a relative. I'm planning on grabbing a PSW125 when I get the money around. I can't imagine you'd suggest anything larger/more powerful than that to back up the A5s?
    Current HT Setup:
    -RTi A5 fronts
    -RTi A4 center
  • ZackaryJim
    edited August 2010
    What do you prefer for break in? Music, frequency sweeps, pink/white noise?
    Current HT Setup:
    -RTi A5 fronts
    -RTi A4 center
  • geebolt
    geebolt Posts: 215
    edited August 2010
    I believe the CS20 is timber matched to the TSI line. You might want to take that into consideration. That said, I think the RTi A5 are the better speaker but the TSI500 ain't bad either.
    Fronts: Polk RTi A7's
    Center: Polk CSi A6
    Surrounds: Polk TSi500's
    Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
    Amplifier: Emotiva XPA-5
    Processor/AVR: Emotiva UMC-1
    DAC: Emotiva XDA-1
    CD player:Emotiva ERC-1
    Blu-Ray: Oppo BDP-93
    Turntable: Kenwood KD-500
    Tonearm: Polk-Mayware Formula 4
    Cartridge: Shure M97-XE
    Television: Sony KDL-55EX500
    tonyb Posts: 33,072
    edited August 2010
    I'd still up the sub choice. It's not about just the 5's,but for a HT room,you want those big explosions to come up and scare you. I would at least look at the 505 on up or a def tech sub since you work at BB.
  • mrbiron
    mrbiron Posts: 5,721
    edited August 2010
    I've been breaking in my A5's with good ol fashion Music, Movies, and VG Sound Effects!!
    I can honestly say that i demoed both the TSI500 and the A5's.......By my sig, you can see that i didn't buy the TSI500's. I listened to them both in a HT setup only so i had to experience the music myself after the fact. The A5's, though didn't blow the TSI500's away, were a much cleaner, more accurate sound.
    Plus they look nicer :D
    Just be prepared to add a receiver that can send some power to them because my first receiver did them no justice. They sounded muddy with just low power.
    You can find reviews on them all over the internet. I didn't read a bad review when i was ready to purchase and the combination of the above, is why i went with the 5's.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2010
  • packetjones
    packetjones Posts: 1,059
    edited August 2010
    i have not heard the 500's. My buddy had the 400's and the sound good. maybe a little harsh but it could just be his setup. I have the A5's and love them. I would vote for the RTIA series myself. Just a better quality cabinet in my opinion. Well worth the additional $37 each.
    -edit-
    Keep in mind that you will need to match the center as well.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • ZackaryJim
    tonyb wrote: »
    I was planning on that sub, but since it's dc'd I can't get it with my accommodation. Although, it's a pretty good deal though Newegg, et al. Anything currently in production that you think is comparable? Something in the DSW line?
    Current HT Setup:
    -RTi A5 fronts
    -RTi A4 center
  • bopicasso
    I would look at other brands besides polk for a subwoofer. SVS, HSU Research, ED, etc.. Better boom for your buck.
    WELCOME TO CLUB POLK!
    The consensus seems to be Rti-A5s....and they are a good speaker...but they are 'sharp' on top for 'music'. So if you're mostly a HT guy the A5s are your speaker. If not....make sure you get amplification that tones that tweeter down!
    I agree with b-picasso above....look around. Elemental Designs, in particular features some pretty good lower end prices on decent subs. SVS and HSU are generally a bit more cash..but not that much.
    Also if you want to go a little higher...check out the NEW Epik subs!!
    cnh
  • ZackaryJim
    Norm Apter wrote: »
    Forgot to mention, my AVR's rated at 110 watts @ 8 ohms. Think that's enough to push them? They're rated at 90dB efficiency, so that seems like they should be alright. If not, any suggestions for a standalone 2-channel amp?
    Current HT Setup:
    -RTi A5 fronts
    -RTi A4 center
  • ZackaryJim
    I'm very much into high-quality music. (I try not to label myself as an audiophile to avoid the stereotypes. I also don't believe in magic speaker cable.)
    So I want my setup to be very musical, and as linear as possible. I'm going to be putting some money into acoustic treatment for my room, since it's currently abhorrent and is definitely my current bottleneck. So as far as a sub, I want something accurate and flat to 20hz if I can swing it. As far as the A5s being 'sharp', my AVR does have an 8-band eq, so I can trim them down a little.
    I am, however, a poor college student. So the cheapest way to accomplish my goals is definitely the best. I.e. anything sold at Best Buy, is a great way to go. :) Obviously I don't mind going somewhere else if the price is right. I think we get a pretty [damn] good price on DefTech, though. I've always heard good things about their subs.
    Current HT Setup:
    -RTi A5 fronts
    -RTi A4 center
  • ZackaryJim
    And... I keep forgetting to post details. My room's only ~15' x 12'. So I don't need earth-shattering SPLs from the sub.
    Current HT Setup:
    -RTi A5 fronts
    -RTi A4 center
  • mystik610
    mystik610 Posts: 699
    ZackaryJim wrote: »
    HSU subs are particularly known for their musicality. This is was the deciding factor for me when I was demoing my HSU against an SVS in my home, and decided to send the SVS back.
    I would contact the guys at HSU (and SVS too) for advice. I've worked with both, and they're all very knowledgable, helpful, and best of all, won't push you into buying more than you need (or can afford).
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • Norm Apter
    ZackaryJim wrote: »
    Yes, that should be fine so long as you don't have a huge room. I use my RtiA5s mostly for HT, but my Denon AVR which drives them also runs 110 watts @ 8 ohms and there seems to be plenty of power for our small/medium-sized living room. My wife does use the HT set up for listening to FM radio and the sound is fantastic for that.
    One of the essential features of the Denon for me was pre-outs. When we move and have a bigger listening space in the future, I'll most likely pick up an external amp. All that said, yes, the Rtias are very easy to drive and right now I don't feel the need for extra power.
    As for 2-channel, I'm afraid I haven't done any critical listening with the RtiA5s because I have only a rather no-frills Philips DVD player hooked up to the HT (no CDP). I have my dedicated 2-channel rig (Lsi9 set up) in the same room so I always used that when I want to engage in 2-channel listening.
    2 Ch.
    HT
    Denon 2808ci AVR
  • mo976
    mo976 Posts: 15
    skip the psw series and head for the dswpro or micropro if you can afford it I was at the same crossroad and instead of the psw111 went for the dswpro400 but if you want 20hz you will need the 600
  • ZackaryJim
    Ordered the RTi A5s today. I also placed a bid on a used SVS PB-10NSD sub. Can't wait for them to get here!!! :D
    Current HT Setup:
    -RTi A5 fronts
    -RTi A4 center
  • flyfisher
    flyfisher Posts: 220
    Congrats and enjoy your new speakers and sub:)
    Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
    Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    ZackaryJim wrote: »
    I believe you may learn many things here, the journey begins.
    RT1
