SDA 1.2tl crossover upgrades
Toolfan66
It's been awhile since I upgraded my 1.2's to 1.2tl's
I have another set of crossovers and these are 1.2tl crossovers. I just want to double check my list of parts.
Caps:
12uf. X3
27uf. X1
13.5uf. X1
Resistors:
11.5. X1
7.5. X1
15. X1
2.7. X1
22.5. X1
I want to just bypass the poly's. Should I use the .05 resistors. I didn't use anything in my 1C's and they have been fine..
Am I missing anything? I want to get my parts ordered from Sonicaps or should I try something else since I have sonicaps in my other crossovers??
Thanks!!!
Caps:
12uf. X3
27uf. X1
13.5uf. X1
Resistors:
11.5. X1
7.5. X1
15. X1
2.7. X1
22.5. X1
Thanks!!!
Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s
SVS SB16 X2
Post edited by Toolfan66 on
Larry,
Not sure about the caps and stock resistors (as I don't own 1.2's or 1.2TLs) but I would definately use the .5 ohm resistor instead of just a jumper to replace the poly. I started with just the jumper (as that is how the 3.1TL's come) but then added the .5 ohm resistor later and made a nice difference in the high end. I recommend it, but it's a matter of taste.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Maybe you put in some Dynamicaps. Not sure if they sound better as I had nothing to compare with.HT/2 CH
McIntosh MX120, MC500, MC206, MEN220
polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect. -
Looks like you are missing a 0.25 uF cap
http://www.polkaudio.com/forums/showthread.php?t=37333&highlight=solen_________________________________________________
You have an extra set of crossovers? where were you able to pick up a set like that?
Are you going to be doing the upgrade by yourself or you going to have Ben do them for you? You dont happen to have pictures of the 1.2's and the 1.2TL crossovers side by side do you?
I still do the 1.2 to 1.2TL mod.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I sent you a PM and am still waiting for you to respond to me on the price..
I want to go ahead and order the rdo198's but am waiting until I get my plan for the crossovers worked out. -
Anyone have a way to contact Ben? I do not think he is getting my PM's. I want him to do my TL conversion on my 1.2..Please let him know I am looking for him.
I'll shoot you a price tomorrow.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
You don't love me anymore??:p:p
Call me later, I have not heard from you since you moved. Figured you have been getting settled in and all..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
I still love you, but you never answer the phone!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
LOL i will call you Later....Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
That's a fact JACK!!! Nor replies to PMs. . . shame on you Larry!!!:p:D -
Come on fellas you know these guys had me running a muck with the ring orders...11 hour days at work as well it was crazy...
I just got caught up last week...
I still love ya all....;)Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
TOOLFORLIFEFAN wrote: »Come on fellas you know these guys had me running a muck with the ring orders...11 hour days at work as well it was crazy...
You do great work Larry.. there is nothing but love for you here on the forums. Thanks for the help with the rings as well.. -
This are no kissy face icons here. hehehe! -
Larry/Ben,
Do I have to mail the inductor at the bottom of the board (The one screwed to the plate) to Ben along with the boards? From the diagram it shows that that inductor has a slight difference between the 2 versions. (.8mH). This is for the TL upgrade. -
Do not send the Inductor.... Ben will not need it..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
SDA SRS 2.3TL's
SDA 2B TL's
