AMP ventilation / heat question
kevhed72
I have been scouring the web for months for a decent plasma stand to work with my gear....I'll cut to the chase. What is the MINIMUM distance you would leave between the top of your amp, and the next shelf above it, assuming the SIDES and BACK of the stand are completely open. The cooling fins are on the side of my particular amp....
Here is a link to the stand that caught my eye:
http://www.studiotech.com/pages/ProductPhotoPopup.aspx?productID=223
Post edited by kevhed72 on
Six to eight inches.Political Correctness'.........defined
President of Club Polk -
Those distances should be in the users manual for your equipment,if not,contact the manufacturer for the correct answer.Different mfgs. recommend different clearances for their equipment.If you can't hear a difference, don't waste your money.
