Settings help
LandShark
I have a sony BDP-S350 connected to an Onkyo 705. Under Audio Settings in the Sony, what do I set these to for my best sound and to let the Onkyo decode without the interference of the sony? Thanks for any help!
TV: Samsung LN40A550
Mains: Polk Monitor 70's
Center: Polk CS2
Surrounds: Polk OWM3's
Receiver: Onkyo TX sr705
BDP: Sony S350
Subs: Velodyne VRP1200 and VRP1000
Monster Power Conditioner EP IR 2450
Post edited by LandShark on
Ok, I went through the owners manual and I think I have this fixed. I have had a problem with blurring issues with blurays and Sony Support had me do a system reset. It fixed my picture issues but if I go through "Easy Setup" and set it to HDMI and 1080p it comes back. If I don't do this will I still get my best picture? Dark scenes are terrible when this setting is allowed. Faces are blurring with any and all motions....help?
Center: Polk CS2
BDP: Sony S350
Monster Power Conditioner EP IR 2450 -
Isn't there a way to set the blu ray player to hdmi and 1080p without using the "Easy Setup"? Sony is usually pretty good at allowing access to their settings through menus, and I usually avoid the auto-detect features like the plague...
I think so, i will try that. Thanks!
Center: Polk CS2
BDP: Sony S350
