RT800i minor restore help
thejck
thejck Posts: 849
edited August 2010 in Speakers
I have some vinyl lifting on my rt800i.Any suggestions on how to fix this. A glue or something. Is there another coat I can put on the speaker if the vinyl is not salvageable?
Also I need spikes for these speakers. What is the width I need to look for?
Post edited by thejck on
  • w_coyote
    w_coyote Posts: 66
    edited August 2010
    I would try some elmers glue. Maybe use some tape to hold it in place until it dries. If that don't work then I would try some contact cement. With contact cement you need to make sure it is where you want it before anything touches. When it makes contact thats it, there will be no moving it. You can get it apart but you will tear it in the process. I think parts express sell replacement vinyl but not sure how you apply it.
  • thejck
    thejck Posts: 849
    edited August 2010
    elmers glue does not work. it keeps lifting. right now I have some black electric tape holding it on
  • messiah
    messiah Posts: 1,790
    edited August 2010
    Please post some pics so we can better assist you.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • thejck
    thejck Posts: 849
    edited August 2010
    On the lower half of one of the speaker the vinyl that wraps around the front face is peeling back. it might have shrunk as well because I dont think it wraps all the way back.
    and on the bottom board it is peeling back as well. i put some black electric tape on it to make it look pretty. I will see if I can get a pic for u guys.
    Also what size thread for the spikes on that speaker?
