New Subwoofer PSW 650
rise
Hello!!
I am a proud new owner of a PSW 650. Does anyone have a number one set up wiring plan?? Should I just use the cable to the lfe?? Thank You for your input.Bob:)
Post edited by rise on
Hi, and welcome!
If your receiver or preamp has a low-pass filtered sub out and you're happy with the crossover freq that it uses, then yes, you probably should just use a single cable from the sub out to the LFE input. The best setup really depends on what other equipment you're using. More info would be needed in order to give you more specific advice. Good luck!
Jason
