converting to 2- channel
leftwinger57
leftwinger57 Posts: 2,917
edited August 2010 in 2 Channel Audio
HI guys, I'm new to the forum and hope I do this right. I decided that I wasn't all that impressed w/ or didn't want to invest in in movies, so I went back to 2 ch stereo. I got an Adcom gfa 555 200w amp some c/l infinitys and wanted to use my Yamaha rx665a/v for the pre. Well after multiple back and forths w/ Yamaha they said because the Adcom had no vol control I needed an indy pre-amp. Not what I had intened or what I was told. I did get an Onkkyo pre at a garage sale , but still don't like the fact I can't use the
Yamaha. All works well and the Adcom is a beast.
h/t
Yamaha rx v665
Klipsch 500 spks
Denon 1920 dvd
2-ch
Adcom-gfa555
Infinity sm112s
Onkyo p-103 pre-amp
  • fishbones
    fishbones Posts: 947
    edited August 2010
    Welcome to CP!
    Well, you have a pretty good amp already. Why do you want to keep using recievers for a preamp? Depending on this answer....my recommendation is to go tubes on the pre. I have noticed a world of difference between SS and tube pre. Tube was waaaaay better sounding - more open, smoother, non-fatiguing. Plus, you have horns - they love tubes!
    Oh, and if you hang around here awhile, you'll probably want Polk SDA's - I'm converted....ohmshala ohmshala ohmshala
  • coolsax
    coolsax Posts: 1,826
    edited August 2010
    not sure what yamaha was telling you, but I currently use my 665, as pre with my parasound 2 channel amp.. I have it hooked up to the main L&R pre outs and it works just fine, so you should still be able to use it as a pre if you wish, though i'll be honest even if its older and cheaper the Onk pre is probably a better sound pre since it that's its main purpose.. 2 channel.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • bluecomet
    bluecomet Posts: 1,118
    edited August 2010
    I would go with a dedicated pre amp weather it is a quality SS or Tube pre. I am not familar with that Yamaha model but if it has pre outs I am not sure why you could not use it in stereo mode for 2 channel. Try it you may like it. Hook up your adcom to your pre out mains. It should work. I have no idea why Yamaha reps would tell you it won't work. It makes no sense.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • steveinaz
    steveinaz Posts: 19,546
    edited August 2010
    Welcome to the dark side. I'll go surround right after I grow 3.5 more ears.
  • leftwinger57
    edited August 2010
    thanks for the welcome and advice . I never thought I'd get the response I
  • fishbones
    edited August 2010
    Some other things to consider, is how you have your speakers positioned. I am also switching from a HT system back to my roots of 2 channel. During HT setup, I did speaker placement according to family freindliness instead of sound, thinking the SQ wouldn't be as important with HT as 2 channel.
    When I converted back, the first thing I did was start experimenting with placement of speakers through A+B listening sessions, and maaaaan oh man did it make a difference! I knew it would from past experience, but it still wows me how drastic the SQ changes just by moving speakers around.
  • leftwinger57
    edited August 2010
    my Infinitys are in a totally different config than h/t in same room. thanks again
  • leftwinger57
    edited August 2010
    Hello again, todays minor problem is my new/old speakers.
    I a pair of pristine Infinity SM112s and as all the reveiws I
    have read the bass bottom end is well not of the deepest .
    I do have a Klipsch 8in sub doing nothing and was wondering
    if there was any way to incorperate into the system.
  • leftwinger57
    edited August 2010
    HI, again, I'm dealing w/ the pre -amp issue and it's not that
    terrible.Todays question goes like this, my new/ old Infintys
    are not the most bottom heavy spkrs. I've read many reveiws
    and I would agree.Keep in mind I paid $45 for a pristine pair,so
    is there any way to incorperate my Klpsch sub some how.
  • steveinaz
    edited August 2010
    Want my opinion? Ditch the sub and work on speaker placement to enhance bass if necessary. There are 2 kinds of bass; tuneful and boomy. Accurate bass is sometimes mistaken for "too little" bass. I remember the SM112's well, as a fellow soldier had them in the barracks when I was stationed in Germany in the 80's.
  • fishbones
    edited August 2010
    Sounds familiar....
    fishbones wrote: »
    Also, using the reciever as a pre, I'm sure is robbing bass from your speakers.
  • steveinaz
    edited August 2010
    I tried to integrate an SVS into my 2-channel years ago; did all the freq sweeps, had it set "optimally" blah, blah, blah---it still sounded overly boomy and like 1 note bass. I later sold the SVS. I couldn't get a satisfying mix out of it.
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2010
    I always use my subs with music. Speakers do have their limitations on how low they can go & they miss a lot in the music because of it. So if you have a sub use it.
    Steve, an SVS sub really is geared for movies. He should get a smaller sub that will simply enhance the music.
  • leftwinger57
    edited August 2010
    I know that the whole idea of forums is to
    exchange info and opinions.I've received both
    and things will stay the way they are. Thanks
