Interesting discovery for older amps
dee1949
....recently my B&K amp was losing one channel, sometimes just for seconds while playing. Found by playing with the fuse cap it would come back to life. I used tin foil inside cap to make a tighter contact. That seemed to work, but I didn't like the idea of tin foil. A friend who has a stash of fuse caps gave me a new pair. Not only did it fix the problem, but it seems it added about 20% more power to the speakers. Does that make sense?? The new caps have springs inside to make better contact.
...Before, I would need 1/2 volume with TT to play reasonably loud....Now 1/3 does the job. On cd at 1/3 volume ....my neighbors call!!! Check your fuse caps to make sure they are making proper contact.
Learn something NEW everyday!!!
Post edited by dee1949 on
And I thought fuses didn't do much.
Thanks.Most people just listen to music and watch movies. I EXPERIENCE them. -
You gotta get the platinum plated ones for the best effect.Ludicrous gibs!
Oh man, this is gonna get good!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I'm not denying the effect of new fuses. Chances are, his old fuses had gotten weak from the years of current passed through them. Remember, they are just tiny strips of metal (kind of makes you think about your big fat power cords, doesn't it). I've seen fuses test "good" with a voltage test, yet still show higher resistance. With higher loads than idle, this can make a big difference.Ludicrous gibs!
hmmm, thanks for the tip Dee
Bingo!
I'll add that both the fuse ends and the holder ends should be cleaned every once in awhile to remove oxidation.Political Correctness'.........defined
President of Club Polk -
tony millard wrote: »And I thought fuses didn't do much.
Thanks.Bingo!
I'll add that both the fuse ends and the holder ends should be cleaned every once in awhile to remove oxidation.DARE TO SOAR:
