M5jr+ Series 2 New Capicitors and RD0198-1
fin1211
Hey everyone.
I have a pair of the m5jr+ series 2s and i was thinking of replacing the tweeters with rd0198-1s because one of my tweeters is blown out and i figured i should just replace both. i have heard that replacing the caps helps a lot. i dont know how to do that...helps appreciated.
thanks everyone
thanks everyone
Post edited by fin1211 on
Jay
Welcome to Club Polk! Replacing the capacitors will make them perform a bit better and ensure they will last many years to enjoy.
If you need help I am an IPC Certified Solderer / Solder Trainer and will gladly perform the mod for you.
Best regards,
Eric. -
You will want to use RDO194 tweeters for the replacement, and let me know if you have any questions on the crossovers or other Monitor 5jr+ mods.
Every where it says I should use rd0198-1s since I have sl2500s
Just wodering -
Conradicles wrote: »Welcome to Club Polk! Replacing the capacitors will make them perform a bit better and ensure they will last many years to enjoy.
Best regards,
Eric.
Thank you. I was thinking of replacing my pioneer stereo receiver with a harman kardon 3490. What do u think?
Thanks-Fin
