When will it stop?
PerfectCreature
PerfectCreature Posts: 1,456
edited August 2010 in The Clubhouse
Thieves Could Hack Cars Through Tire Systems
Plus Four Other Vulnerabilities of Vehicle Technology
As our cars become more technologically advanced, they leave the door open for vulnerabilities. Latest in the technological flawbook appears to be tire pressure monitoring systems (TPMS), revealing just how small that hole needs to be in order for a tech savvy thief to crawl through.
A group of researchers from Rutgers University and the University of South Carolina discovered that you can hack into a car's electronics wirelessly though tire systems, which means any modern vehicle could be vulnerable to an attack at any time, even while it's being driven down the road.
In their study, researchers used a car's tire pressure monitoring system (TPMS) as their entry portal. Tire pressure monitoring has been mandatory on new cars since 2008 and uses a sensor on each wheel that transmits data over radio frequencies to a vehicle's electronic control unit.
By sniffing for signals from the TPMS, these researchers were able to track two different vehicles and even interfere with the signals. At this point, the real world implications are limited because TPMS sensors have a very short range and update the car's ECU only every 60-90 seconds. However, these findings underscore how as vehicles get more wireless connectivity, it's important to ensure those wireless connections are secure and encrypted to prevent mischief.
Over the last few years, other vulnerabilities have been found in vehicles. While most of these aren't cause for concern today, they nevertheless point out that that technological advancement comes with compromises.
- Geo-location: Cars with onboard navigation systems are in a never-ending conversation with the sky above. Acting as a unique signal with a series of satellites, your vehicle essentially has its own "mailing address." Locating that address by compromising the satellite network could reveal your location to someone who wanted to find out where you were traveling. What's at stake: your location.
- "Home button" robberies: Related to navigation systems, there have been reports that thieves target vehicles with navigation systems and garage door openers visible. The thinking is that if a thief can get access to your navigation system, he can press the home button (which most drivers program to their real home address) and then use the garage door opener to get inside. What's at stake: Your car and potentially your home.
- Physical Access to the car's brain: In an earlier report, our Craig Howie reported on the dangers of allowing someone access to the OBD-II port of a vehicle, which is the access point for the car's brain. "Someone -- such as a mechanic, a valet, a person who rents a car, an ex-friend, a disgruntled family member, or the car owner -- can, with even momentary access to the vehicle, insert a malicious component into a car’s internal network via the ubiquitous OBD-II port (typically under the dash). The attacker may leave the malicious component permanently attached to the car’s internal network or, as we show in this paper, they may use a brief period of connectivity to embed the malware within the car’s existing components and then disconnect." What's at stake: A lot. Access to the all the vehicle systems can be found here, which means everything from accelerator to brakes.
- "GPS Jammers" Allow Thieves A Getaway: The super technologically advanced thief is looking a few steps ahead. Knowing that many cars come with GPS systems, onboard tracking systems such as OnStar and other theft devices, there have been reports that thieves are buying GPS jammers from China. These systems essentially block the car's own GPS signal, preventing the law from locating the car. What's at stake: the safe return of your car.
That is really upsetting. I mean, you really are not safe at all. I guess your tires can be your downfall?
Oh well. It proves nothing in this world is safe.....
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Post edited by PerfectCreature on
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited August 2010
    None of that is cause for any concern. If a thief steals your car, sucks to be you but having a home button isn't some savvy way to get in someones house. By the time they arrive, the cops could get to your home. Also, if someone wants in your garage door, that little frequency that opens it is easy enough to get.
    Knowing your location... i'd be more afraid of the cops using it than anyone else.
    OBD-ii... what a joke. physical access.
    TPS? those work from feet away. what harm can they do with that that they couldn't do with a baseball bat?
    GPS Jammers... OMG A THIEVES GETAWAY... well, if you don't have the GPS (the crazy technology that they get at you from!) then they don't need to jam it.
    I don't understand why the news is always out to scare people.
  • obieone
    obieone Posts: 5,077
    edited August 2010
    I'm more afraid of zombies.
    nooshinjohn Posts: 25,383
    edited August 2010
    obieone wrote: »
    ...and 12/12/2012;)
  • dkg999
    dkg999 Posts: 5,647
    edited August 2010
    After the first electro-magnetic pulse weapon goes off those tire pressure monitors are going to be pretty worthless.
    DKG999
    F1nut Posts: 50,474
    edited August 2010
    dkg999 wrote: »
    Hehe.....
  • Ron-P
    Ron-P Posts: 8,516
    edited August 2010
    Try to imagine all life as you know it stopping instantaneously and every molecule in your body exploding at the speed of light.
    Total protonic reversal
    Right. That's bad. Okay. All right. Important safety tip.
    If...
    Ron loves a film = don't even rent.
  • bobman1235
    bobman1235 Posts: 10,822
    edited August 2010
    I heart fearmongering.
  • mrbigbluelight
    mrbigbluelight Posts: 9,696
    edited August 2010
    Although I don't have TPMS on my Neon (even though it is the SXT DE-LUXE model :eek: ) I've taken the precaution of lowering the air pressure in my tires to 1.75 psig as a means of preventing theft.
    ...... kind of puts a dent in the gas mileage, but ........ does a lot for traction ! Except on corners ...... dam tires keep coming off the rims on sharp turns. :(
