Question about retainer rings SDA 2B MW
helipilotdoug
helipilotdoug Posts: 1,230
edited August 2010 in Vintage Speakers
I am in the process of replacing the tweeters, and installing Larry's rings on my 2B's. Take a look at the attached photo. I think this speaker must have been made late on Friday afternoon! As you can see the center brace is way over to the right, and actually overlaps the hole by a mm or 2. What is the best way to make the ring fit? Cut off the ring to match the opening, or cut down the wood to allow the ring to fit?
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
Post edited by helipilotdoug on
    Toolfan66 Posts: 18,063
    edited August 2010
    I would just cut the ring to fit.
  • Conradicles
    Conradicles Posts: 6,343
    edited August 2010
    I would cut the ring.
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited August 2010
    Don't listen to these guys. Cut/grind the ring, that's what I did.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • helipilotdoug
    edited August 2010
    Thanks guys. So much needs to be removed that the ring will be cut off completely on one side. I'll put it in a vise, and use a hacksaw. Wish I had Larry's laser!:D
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • helipilotdoug
    edited August 2010
    Done and done. :D
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • helipilotdoug
    edited August 2010
    Had the same problem with the other speaker yesterday. The center board was over to the right about the same as on the first one, I was thinking, perhaps this was designed into the speaker for some reason. However, I doubt it since the boards were both over to the right, in both speakers, which would not make sense. The volume of the stereo driver compartment vs the SDA compartment would be different, so I doubt it was designed into the speakers. Like I said before, I have a feeling these speakers were built on a Friday afternoon!
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • inspiredsports
    inspiredsports Posts: 5,502
    edited August 2010
    . . . and they'll still sound better than most other brands built on a Tuesday and costing 4 times the price! :D
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • helipilotdoug
    edited August 2010
    Oh Yeah! Right you are about that!:D
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
