SDA SRS 2TL's
mole'
mole' Posts: 3,160
edited August 2010 in Vintage Speakers
looking to see what all mods and tweeks are out there for these speakers.
ill be picking a set of them up soon and just wanted to get the info on what i might wanna do to them.
mole'
Post edited by mole' on
  • mole'
    mole' Posts: 3,160
    edited August 2010
    can a mod edit the title to read SDA SRS 2.3TL's please?
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    looking for a good amp to drive these with along with the rest of my speakers.
    will a XPA-5 be good with the SDA SRS 2.3TL's?
    mole'
    F1nut Posts: 51,682
    edited August 2010
    JHC Mole, you're getting a really nice pair of speakers that deserve better than that. As for mods and stuff, stop posting for awhile and get your search on. There's a ton of that info here.
  • george daniel
    george daniel Posts: 12,096
    edited August 2010
    mole' wrote: »
    Belles 350A reference
  • Fatbrando
    Fatbrando Posts: 275
    edited August 2010
    Don't forget those babies can handle up to 1000watts per channel each!
    FB
    Harman Kardon HK 3490
    Stanton STR8-100
    Polk SDA SRS 2.3TL (Proud newbie owner!)
  • meangreen76
    meangreen76 Posts: 5
    edited August 2010
    Check out the Vintage Denon POA series Power Amps. I am using a POA-2400 with my SDA-SRS and they seem to work well as a package. And the amps don't break the bank either.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    Fatbrando wrote: »
    FB
    yup, but that amp is $$$$
    gonna check them out. thanks
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    i have them hooked up to my Acurus 250x3 and they are sounding GOOD! still working on the placement tho.
    mole'
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2010
    2.3 TLs are fabulous SDAs. Power them with a high quality, high current amplifier and you'll be set and smiling for a long time to come.
    As far as upgrades/updates/tweaks go there is more information here about them. All you need to do is spend some time searching and reading. If you get stuck on a search I'm sure someone will point to the right thread you need.
  • Hamatym
    Hamatym Posts: 269
    edited August 2010
    Spikes, RDO-198's, and XO's upgrades are the best....DONE!
    Now if you still want more like me with mine, you can do:
    1) Tweeter, Driver, and PR Brackets from Larry
    2) Dynamat all the Metal Baskets
    3) JB Weld the Driver's
    That's all I got...ha ha
  • mole'
    mole' Posts: 3,160
    edited August 2010
    Hamatym wrote: »
    Rings from larry Check
    RDO-198 Check
    Face is gonna upgrade my crossovers Check
    have to looking into the spikes.
    Dynamat Check
    JB weld the drivers??????
    mole'
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2010
  • gimpod
    gimpod Posts: 1,793
    edited August 2010
    mole' wrote: »
    Not to be a smart a$$ but there is a thing at the top of the page that says "Search" it's your friend.;)
    Seriously here's the link JB Welding Your Drivers
  • mole'
    mole' Posts: 3,160
    edited August 2010
    gim54pod wrote: »
    SORRY! i was thinking he was testing a SDA newb out.
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    leroyjr1 wrote: »
    Pics???
    If a mod sees this, can you add these pics to the first post please???
    its all still coming together. work in progress
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    cross over mods for the 2.3TL's
    2 16uf
    2 8uf
    2 5.8uf
    2 18uf
    2 27uf
    4 22.5ohm
    mole'
    F1nut Posts: 51,682
    edited August 2010
    Sonicap doesn't make an 16, use two 8's instead. Total of six 8uF.
    Sonicap doesn't make an 18, use two 9's instead. Total of four 9uF.
    Mills doesn't make a 22.5 ohm. Use a 10 and 12.5 instead. Total of four each.
    Don't forget the .5 ohm to replace the poly. Total of two.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    i got that info from Face. ill hit him up. thanks
    mole'
    F1nut Posts: 51,682
    edited August 2010
    Hit him up for what?
  • mole'
    mole' Posts: 3,160
    edited August 2010
    he is doing the work to my crossovers on the 2.3TL's
    mole'
    F1nut Posts: 51,682
    edited August 2010
    Yeah ok. He told you what the schematics call for. I gave you what you need to order to match the values on the schematic.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    oh sorry.
    mole'
    Toolfan66 Posts: 17,987
    edited August 2010
    Won't sonicap make you custom values??
  • Face
    Face Posts: 14,340
    edited August 2010
    They do. ;)
    F1nut Posts: 51,682
    edited August 2010
    I didn't think they could make a 15 turn into a 16, just smaller differences like the 5.6 to a 5.8. At least, that's what I remember Jeff saying.
  • Outfitter03
    Outfitter03 Posts: 563
    edited August 2010
    Nice pictures Mole', really starting to come together. How do your new speakers sound? Are you waiting to receive the 5800 before you can try them out?
  • mole'
    mole' Posts: 3,160
    edited August 2010
    THANKS!
    i have them hooked and powered off of the Acurus 250x3. they sound good. they sound really good with HT too.
    mole'
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2010
    mole, new camera time. that first pic makes them drivers look.... funky and out-of-round.;)
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    BIZILL wrote: »
    using my DROID.
    my Sony D SLR is broken. :(
    mole'
