ok SDA just stoped working??
zippty2001
zippty2001 Posts: 232
edited August 2010 in Vintage Speakers
OK well i was listening to some fear factory a little loud. and the speakers made some strange sounds. like the highs faded and came back up to normal. i turned it down and was looking at the speakers and i don't think the sda part is working. any test i can do or a CD that might tell me better than some death metal and yes its all hooked up right thanks for any help.
Post edited by zippty2001 on
  • Conradicles
    Conradicles Posts: 6,138
    edited August 2010
    My guess is that you tripped a polyswitch. Turn them off for a while and try them out later and see if they are back to normal. The polyswitch is designed to protect the tweeters from being blown.
