RTi10 vs Monitor 70
mole'
mole' Posts: 3,160
edited August 2010 in Speakers
wanted to see how the RTi10 compare to the Monitor 70s?
would be using these are my rear speakers with a set of RTi12s, CSi5 and an Epik castle sub. powered by a SC-07, Acurus 250x3 for fronts/center and an Adcom 100x2. still looking for a nice 5ch amp to power everything. (also having the x-overs in the RTi12/CSi5 modded by face)
room is 20x18 75% HT/Games 25% Music
RTi 10 $249.99 each
Driver Complement
Woofer 2 - 7" Diameter (17.78cm)
Polymer Composite Cones with Rubber Surrounds
Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
Polymer Composite Dynamic Balance Cones with Rubber Surrounds
Tweeter 1 - 1" Diameter (2.54cm)
Silk/Polymer composite dome
Electrical
Overall Frequency Response 20Hz-27kHz
Lower -3dB Limit 35Hz
Upper -3dB Limit 26kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20-300 w/channel
Efficiency 89 dB
Crossover
(mid-high array) 2.7kHz, 12dB/octave low and high pass. 125Hz 12dB/octave high pass
Crossover
(subwoofer) 125Hz, 12dB/octave low pass
Inputs Dual (bi-amp) gold plated 5-way binding posts
Dimensions
Cabinet Size 43-5/8" H x 7-3/4" W x 17-1/2" D
(110.81cm H x 19.68cm W x 44.45cm D)
Enclosure Type Vented via Power Port Plus
Monitor 70 $199.00 each
Driver Complement
Subwoofer 2 - 6-1/2" Diameter (16.51cm)
Dynamic Balance Bi-laminate composite cone drivers, magnetically shielded
Mid/Woofer 2 - 6-1/2" Diameter (16.51cm)
Dynamic Balance Silk/polymer composite dome, magnetically shielded
Electrical
Overall Frequency Response 30Hz - 25kHz
Lower -3dB Limit 40Hz
Upper -3dB Limit 24kHz
Recommended Amplifier Power 20 - 275 w/channel
Efficiency 90 dB
Crossover 2.6kHz and 2.6kHz cascade tapered 2nd order
Inputs Dual (bi-amp) 5 way binding posts
Dimensions
Cabinet Size 42" H x 7-3/4" W x 14-3/4" D
(106.68cm H x 19.68cm W x 37.47cm D)
Enclosure Type Vented via front panel flared port
mole'
Post edited by mole' on
  • SivaNevets
    SivaNevets Posts: 303
    edited August 2010
    RTi10 much better than Monitor 70 in HT. much detailed forward tweeter makes HT extremly involving.
    for music Monitor 70 is better, only because RTi10 is too bright for music.
    since you have a good amp, i highly recommend to get RTi12/RTIa9.
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • mole'
    mole' Posts: 3,160
    edited August 2010
    SivaNevets wrote: »
    thanks
    i was gonna get the RTi10 over the M70 cause they are 249 a pop. i already have a set of M70 but they are messed up. RTi a9 look great but $$$
    mole'
  • bopicasso
    bopicasso Posts: 878
    edited August 2010
    Keep it timber matched with the RTI 10. It will sound better for ht.
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited August 2010
    It'll look cooler with all RTis!! :)
  • GoBigBlue
    GoBigBlue Posts: 212
    edited August 2010
    bopicasso wrote: »
    You said it would sound better for HT. Would it sound the better or the same for music? I'm looking at some 70s myself.
  • geebolt
    geebolt Posts: 215
    edited August 2010
    I have RTi A7's which are pretty much the same as Rt10's and I also have TSi500's which are pretty much the same as Monitor 7's. I drive them with an Emotiva XPA-5 and an Onkyo TX-NR807 used as a pre/pro.
    I can tell you first hand, the RTi's are better for both HT as well music in my room. I do like the 500's, its just that I like the A7's more. A much more open and clearer sounding midrange is the biggest difference but better bottom end and highs as well.
    George
    Fronts: Polk RTi A7's
    Center: Polk CSi A6
    Surrounds: Polk TSi500's
    Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
    Amplifier: Emotiva XPA-5
    Processor/AVR: Emotiva UMC-1
    DAC: Emotiva XDA-1
    CD player:Emotiva ERC-1
    Blu-Ray: Oppo BDP-93
    Turntable: Kenwood KD-500
    Tonearm: Polk-Mayware Formula 4
    Cartridge: Shure M97-XE
    Television: Sony KDL-55EX500
  • bopicasso
    edited August 2010
    RTi/RTiA models are more expensive, and above the monitor/tsi series for a reason.
    Because they are better quality and better sounding speakers. I have 3 friends who have monitor series speakers, and I owned the RTi8s. I would go with the RTi series everytime.
    No brainer in my opinion.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    geebolt wrote: »
    George
    how do you like the XPA-5? i have been looking at picking one up.
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    thanks for everyones inputs.
    RTi10 looks like it will be.
    just gotta work down the shipping cost from J&R now.
    mole'
  • geebolt
    geebolt Posts: 215
    edited August 2010
    mole' wrote: »
    I wish I'd gotten one sooner! Better late than never, however.
    Sound overall is much mor open, better seperation between instruments, and listener fatigue has not been a factor for me so far.
    And it runs much cooler than the Onkyo ever did.
    George
    Center: Polk CSi A6
    DAC: Emotiva XDA-1
  • mystik610
    mystik610 Posts: 699
    edited August 2010
    mole' wrote: »
    Having picked up an XPA-5 myself, I wouldn't pair it with the RTi's. It's a pretty bright amp, and doesn't have good synergy with the RTi's.
    I have an XPA-5 driving my system right now, with FXi3's driving my rears...the highs from my rears are a bit much with the XPA-5.
    You definitely want a warmer amp with the RTi's. I was using an HK amp (very warm) with my RTi8's, and they had a very good synergy. Part of me wants to go back to the HK even with my LSi's.
    Just my 2 cents.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • mole'
    mole' Posts: 3,160
    edited August 2010
    geebolt wrote: »
    George
    so you like the XPA-5 with the RTi's. not too bright at all?
    mystik610 wrote: »
    Just my 2 cents.
    and then you dont like it.
    which HK amp would you get in a 5 Ch?
    mole'
  • mystik610
    edited August 2010
    mole' wrote: »
    The jury is out on whether or not I like the XPA-5. I'm going to play with the EMO for a couple of weeks and try my HK again, but I'm not terribly impressed with the XPA-5 so far, even coming from an amp that has half as many watts. It's brighter and has more 'sparkle', which brings my LSi9's to life for movies, but it isn't nearly as detailed as the HK. The separation of the instruments isn't as good...the bass is muddier, and subtle details like a singer taking a breath that were present with the HK, are lost with the EMO.
    I spent money on the EMO and want to like it, but I'm not completely sold on it yet.
    All of that is more subjective though. From a more objective standpoint, the EMO is definitely very forward in the upper frequencies....at least relative to the HK. I'm not saying you should go with an HK necessarily (you'll want something more powerful for the RTi10's), but the RTis defintely benefit from a warm amp. In my experience with my Harman Kardon Signature 2.1 and the RTi8's, the HK really brought out the mid-range and gave the 8's a much fuller sound that didn't favor the tweeter quite as much. Some say the EMO is bright, others say its neutral.....all of that is relative to what you're used to, but the EMO isn't by any means a warm amp.
    just my 2 cents.
    My System Showcase!
    Media Room
    Living-room
    Headphones
  • mole'
    mole' Posts: 3,160
    edited August 2010
    im gonna need an amp that can power the RTi12, RTi10 and a CSi5
    dont wanna spend over a G tho
    mole'
  • Gulfstrings
    Gulfstrings Posts: 313
    edited August 2010
    Purchased my NAD T955 at Audio Advisor on sale and well within your budget. Couldn't be more happy with the way it works with the RTi setup. No brightness, no listening fatigue, just an excellent, very musical amp.
    And it does a great job with HT!
    Dave
    http://www.audioadvisor.com/prodinfo.asp?number=NAT955
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
  • mole'
    mole' Posts: 3,160
    edited August 2010
    Dave
    nice looking amp. :D but its only 100wpc@8ohms.
    would i just be better off staying with my current amps? Acurus 250x3 / Adcom 100x2 ?
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    what ya think about these amps?
    B&K - AV5000 Series II 125 wpc 5 channel Amplifier
    Parasound - 5125 125 wpc THX Ultra2 Five-Channel Amplifier
    mole'
  • Gulfstrings
    edited August 2010
    mole' wrote: »
    Those 100 watts per channel are legit - real power. But if you're having second thoughts about replacing your current gear with a single five channel unit I can't imagine you wouldn't be happy with the just the speaker change.
    Incremental change is always a good idea ...
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
  • geebolt
    geebolt Posts: 215
    edited August 2010
    Yes, I like the XPA-5 with the RTi's. I run Audessey from my Onkyo TX-NR807 and the end result is very good. The only thing I have to play with is the bass level. The high end sounds fine to me. But as I said, I've always run Audessey first whenever I add new equipment.
    Center: Polk CSi A6
    DAC: Emotiva XDA-1
  • mole'
    mole' Posts: 3,160
    edited August 2010
    thanks.
    found a set of SDAs in SoCal that i want more than the RT1s now. so this might all change now.
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    geebolt wrote: »
    gonna have an Epik Castle sub here soon for the extra BASS
    mole'
