Even more progress
VR3
Sweeetness
Sconces are mounted - back overhead light is mounted.
The side walls that appear white in the picture are actually a light tint of blue
It goes real well together - the dark blue is the same color of blue found in the rug in the den and the curtains in the kitchen
Post edited by VR3 on
I don't think I ever seen some many electrical boxes on one wall before in my life.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Yeah - I came in one day and Russ had cut enough outlets to wire up a mansion on that one wall.
Somehow I cut all the holes in the drywall without mistake!
haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Lookin' good kid, lookin' good. That house will be ready for a Polkfest in what? 3 years?
Whatcha' got in mind for flooring in the hallway and the 3 bedrooms? Please don't tell me Shag carpet.....:rolleyes:~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
will be dark wood flooring in the spare room and probably light wood flooring in the hallway.
Thanks man! I still **** in your general direction though biotch- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
MmmmmmmmmmmmmmmmK, well, I take it that the spare BR will have hardwoods as well? With all the electronic gear in there, I would hate for static electricity from a carpet to screw everything up in ways you or I can't even fathom right now.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
There will not be a single piece of carpet in the house. Hate* I repeat, HATE****************** carpet.
Hardwoods 100000000%
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You know looking at all those outlet boxes.....
I beginning to think Russ / Lightman works or worked for NASA or some Nuclear power plant or something.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »You know looking at all those outlet boxes.....
