Building a box
Halflungshort
I'm going to be building a box for my 10" gxr. My question is does it matter which parts overlap. ( top/bottom over front/back ) or the other way. I will be using 3/4 mdf. I have not decided what to cover box with yet.
Post edited by Halflungshort on
My current measurements are the top/bottom overlapping front/back. If needs to be different this will change my measurements. Plans to start build this week. Will post picks during the process
I usually make the side with the woofer whether it's on the side or top or bottom the full measurement. So if the box is 14"X16"X24" and the woofer is on the 16" side then I make that piece of wood 16"X24". If the woofer is on the 14" side then that piece is
14"X24". This also makes a general slot ported box easier to build if you are porting the box on the same side as the woofer which most are... -
Ok, I will do it that way. is there a reason for that other than a port? Just curious. Does it help integrity of the structure?
Trying to post pics of my box
LOL i doubt you're still on here, halflungshort...
but try an uploading site like flickr, photobucket, etc.. -
Del-dom reported
