YAAOSP - yet another article on subwoofer placement
quadzilla
But it's a good one. One of the most interesting things about it is this is the first article I've seen that states that getting the sub up off the floor is a must.
http://www.asc-home-theater.com/ht-acoustics-vol3.pdf
I'm working on the math for my room, but it's a bit odd shaped, so REW will probably still be required to get the final tuning done. But for someone setting up a sub (or subs) in a new room, this should get you into the general area of where the subs need to be.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Arm: Rega 300
Post edited by quadzilla on
Having tried positioning the subs based on this article, I can say it works. I've got about 3 db more at 20 Hz and over 20 db more a 14 Hz.Turntable: Empire 208
Arm: Rega 300
