Thoughts on my setup and speaker recommendation
Hi,
I have purchased the following:
Onkyo TX NR-808 7.2 receiver
Pair of RTi A1 for rears
RTi C4 for center
Pro 500 sub
I am trying to setup a 5.1 system in a large room with high ceiling.
Both me and my wife are not fans of floorstanding speakers, so I bought the following bookshelfs.
I am thinking about buying a pair of RTi A3's for fronts.
The only other option would be a pair of A5's which we are trying to shy away from.
Thanks in advance for your thoughts,
Rohit.
RTi C4 for center
Pro 500 sub
Rohit.
Post edited by rosahas on
Welcome to the forum.
I don't have a suggestion because I, unlike you, like full size full range speakers. So I cannot comment on the bookshelf speakers you are asking about but I am sure there will be many opions and options to choose from by other members of the forum.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
I first had polk bookshelf rti6s. Then found a good deal on the rti8s so I bought two pair figuring I can make some money. The soundstage was huge compared to the small bookshelf speakers. For a home theater floorstanding speakers are a must! You will be missing out using bookshelfs for your L/R main speakers.Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
Hi,
RTi C4 for center
Pro 500 sub
Rohit.
Well I have the RTIA5 speakers for fronts with RTI6s(predicessor to the RTI3s) for rears with a csi40 center. This combination foor 5.1 is just great in my 14' x 14' tv room. It really is a nice soundstage. If you can find a way to live with the A5s.
Here is some pics of my setup. If you can locate A5's with cherry finish, they really do look nice.
http://www.flickr.com/photos/renowilliams/"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
To the OP,
do you have kids or pets? Things to consider if you're going to use bookshelves in case they're going to be on stands.
Ideally, you want the tweeter to be between 6" above or below your ears as you sit down. AT ear level would be optimal.
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Hi,
RTi C4 for center
Pro 500 sub
Rohit.
I upgraded from bookshelf speakers to monitor 60's for surrounds - never going back to small speakers. A pair of A5's would not only sound better, but they would class up your room a bit. How far away from your front speakers do you sit? Have you thought about mounting a pair of dipole speakers for the rear channel on the wall?polk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
I happen to like bookshelves myself, but only for a small to medium size room such as mine. Sounds like you are a candidate for full range towers. With a large room (how large?) with high ceilings I think you would not only benefit from full range towers, but an external amp as well. Of course this is also dependant on your listening habits.
It's our living room 20 x 16 ft room with high ceiling. On top it opens up to our kitchen and our breakfast area.
The plan is to mainly watch casual TV and light music. Occasional movies. -
To the OP,
-Freddy
Yes, I do have kids.. a toddler and a 6 month old. Which is why, I am shying away from the floorstanding ones for the most part. Plus, I would like to keep them on the wall if possible. More and more I am hearing positive feedback towards floorstanding so far. -
spock 2054 wrote: »I upgraded from bookshelf speakers to monitor 60's for surrounds - never going back to small speakers. A pair of A5's would not only sound better, but they would class up your room a bit. How far away from your front speakers do you sit? Have you thought about mounting a pair of dipole speakers for the rear channel on the wall?
I would probably sit around 10 feet from the fronts... at least that is the plan.
I am not familiar with dipole speakers.. which ones would they be in the RTi series. I figured I would stay in the same series to be safe.
Thanks. -
renowilliams wrote: »Well I have the RTIA5 speakers for fronts with RTI6s(predicessor to the RTI3s) for rears with a csi40 center. This combination foor 5.1 is just great in my 14' x 14' tv room. It really is a nice soundstage. If you can find a way to live with the A5s.
Nice... .. it's a 16 x 20 living room. I think overall the A5s would probably fit better here. I am just trying to find ways to convince myself. -
OK thx.. another floorstanding vote! -
I'll second what Bobicasso said. I started with the RTi6's as Mains and they worked pretty well in the smaller living room. I bought a new house and the room and ceiling was larger (20 x 24 x 10), it also opens up into the kitchen area.
The Rti6's just wouldn't cut it anymore in the larger room. I moved them to the rears and have the RTi10's for the mains and upgraded my sub. (I also added more amplification, but that is another story).
If you can find a solution to kiddies and floor standers, I too think you would be more satisfied with floor standers.
All Most forgot.....
Welcome to Club Polk!
Scott
PS Perhaps there is a local polkie that would let you listen to floor standers or RTi6's that you could listen too before you buy.Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
Scott
Thanks!
I did hear A5s vs A3's. A5s definitely sound better. I think the kids issues is a bigger one for now. I wish I could do 7.1, but with high ceiling I can't install two more speaker with my room setup at this point.
I might have to just go with A3s for now!
Thanks for all the input.. really appreciate it and looking forward to becoming a polkie myself
Rohit.
