Best antique farm engine show in the world
thsmith
http://www.oldthreshers.com/
60th year. Family atmosphere, smoke, wood, oil, diesel, gasoline, kerosene and steam engines.
Been many times and highly recommend.
I own a 1927 Fairbanks Morse dish pan 2hp (Bosch magnito) stationary motor, 1947 2hp Fairbanks Morse and 3 Maytag (1929-32) 2 stroke washing machine motors.
Post edited by thsmith on
The oldest I have is a 1948 Ford 8N. Some of that older stuff is cool.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
This show is not like any other. Steam tractor sled pulls. 100hp steam tractor is something to hear. The have 3 or 4 steam engines on rails, one is a Baldwin and a Shea.
They have a steam power plant and carousel.
I like the Fords and JD popping johnny's.
MY wife's grandfather would sit and listen to the stack music of a steam tractor powering a double blade Sears wood mill.Speakers: SDA-1C (most all the goodies)
I've always wanted to go to the Old Thresher's Reunion. Maybe some day I actually will.Ludicrous gibs!
It is a great show and a great place to take the family. $20 passes for the show which 5 days.
If you are into engines this is the place to go to see how this country used to farm and live.Speakers: SDA-1C (most all the goodies)
I haven't been to that show for many years. They used to have some great bluegrass music bands playing live.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
May have to check that one out some time since it is closer.
I have been to this one ( http://www.rollag.com/index.php ) several times and really enjoyed it but haven't been for several years because of the drive. -
Holy crap man, now I'm jonesing for a tractor pull. You can take the boy out of Iowa... but ya can't take Iowa out of the the boy.
I love old farm equipment.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I've got an old "Baldwin Gleaner" which is a pull behind, self powered combine that I should let one of those exhibitors have.......not doing much sitting up in the bushes!:( A word to the wise Stay Back a safe distance from any steam equipment operated by an unknown person ! A hotshot newbie blew one up some time back and IIRC, injured/killed some people and self !:eek:The oldest I have is a 1948 Ford 8N. Some of that older stuff is cool.
Does your 8N have the distributor in front or on the side? Great little tractor, the Model T of the field !:) -
GDB, the steam engines at this show are not operated newbees and have to be inspected before firing up, they also limit how much preasure you can generate.Speakers: SDA-1C (most all the goodies)
It's an early front distributor 8N 12v converted.>
Polkersince85 wrote: »It's an early front distributor 8N 12v converted.
12 Volt Good 6 Volt Suck !;) I've had 2n,9n&8n + Ferg. 20:eek:
