surrounds recommendations
rswroughneck
rswroughneck Posts: 22
edited August 2010 in Speakers
I'm looking at going with the rti line for a 5.1 system, for my surrounds I have to mount them pretty high on my walls. I plan on going with the FXI-a6's or the RTI-a3's. I'm thinking for best sound I will need to angle them down a little. mounting height will be about 11 feet.
just wondering if the A3's are better for this setup since they are more directional or if the A6's would be better.
also would the A6's work good without pointing them down?
Post edited by rswroughneck on
