CS350-LS Center Speaker - Drivers Needed
michaelrwalker
michaelrwalker Posts: 5
edited August 2012 in Vintage Speakers
I need two drivers - MW4850. Can anyone direct me to a source? Thanks
Post edited by michaelrwalker on
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited August 2010
    Did you call Polk direct. The 350's are getting a bit older now. Really doubt you will find drivers for them.
  • michaelrwalker
    edited August 2010
    Yes, no joy from Polk. My options are to find comparable drivers, fix them or find used ones. I am not sure which way to go yet.
  • michaelrwalker
    edited August 2010
    I would appreciate input on my three options:
    (1) Replace the drivers with something comparable. I have identified a SEAS Prestige CA12RCY (H1152) that seems similar. These are offered by Madisound Speaker Components, Inc.
    (2) Repair the drivers. I have identified a company - Meniscus Audio Group, Inc. that believes the problem is burned voice coils and they state that the drivers can be completely repaired.
    (3) Find another CS350-LS center channel speaker for sale (they come up on ebay weekly) and use it for replacement parts.
    I can see pros and cons to each of these alternatives, and so I thought I would seek guidance.
  • phocion
    phocion Posts: 157
    edited August 2010
    http://www.polkaudio.com/forums/showthread.php?t=89591
    Might have a few mids left over from that heinous shipping problem.
    I would try and find one via ebay/craigs, because they are closing in on 20 years old, and were high end, so availability is going to be suspect. On the good side, you get extra spare parts.
    I found a CS200 on CL for $15 that I scooped up *just in case*, and the drivers are very similar:
    So, that might be a less expensive alternative?
    The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
  • cincycat13
    cincycat13 Posts: 887
    edited August 2010
    Wow...a CS200 only brought $15? I think I will just follow your lead and leave mine in the closet for a spare...
  • michaelrwalker
    edited August 2010
    How do the drivers in the CS200 (MW4802) compare size wise and performance wise to the MW4850 in my CS350-SL?
  • Vette C6.r
    edited August 2010
    I have a CS 250 and 350. If the drivers are different I sure can't tell.
    I haven't taken them out, mind you.
  • phocion
    phocion Posts: 157
    edited August 2010
    Well, I put them both through a quick sine sweep and some music, and they sound very similar, but of course the 350 is more forceful, tweet has a richer sound, and has a better bottom end. I tried to take a close enough pic to let you see that the speaker dust cover on the 350 is textured, while the 200 is not. Otherwise, they appear highly similar, with the same relative excursion, size, ohm rating, and mounting screw locations.
    So, I won't guarantee they are an exact match, but I think they would work in a pinch. I grabbed the CS200 on a lark because it was cheap, and I spent nearly as much in gas to get there and back as I did on the speaker :) I think finding a 350 would be your best bet though, instead of mixing drivers. If you can find one that has a broken grill or scratched cabinet, even better, because it should go cheap, and you just need the parts.
  • cstmar01
    cstmar01 Posts: 4,424
    edited August 2010
    I have one for sale here on the forum. it is cracked however but still is in decent shape.
    btw there is a difference between the drivers in the 250 and the 350 the 250's are not magnetically shielded.
  • dpowell
    dpowell Posts: 3,068
    edited August 2010
    phocion wrote: »
    Well, I put them both through a quick sine sweep and some music, and they sound very similar, but of course the 350 is more forceful, tweet has a richer sound, and has a better bottom end..
    Probably due to a better XO in the 350 and cabinet size.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • fitness1
    fitness1 Posts: 16
    edited August 2012
    Just saw this old post and sent you an email......
