ghetto components
systemcra
Long ago and far away I bought 4 ex502 for my car. This was my first install and it sounded good. No sub, no amps, just replaced factory headunit with mid-fi Pioneer and redid factory speakers. Now I am adding a sub and amp and I have a pair of ex2500 tweets. I would really like to utilize them up front, but my 502s already have tweets in them. What to do?
I'm a home audio guy, all polk home theater, so I try to apply the same ideas to car audio. Wouldn't imaging be bad w/ 2 tweeters firing from different locations? They are roughly the same distance from the ear at least.
What if I were to disable the ex502 tweeter, I really don't want to cut the wire, I might just put some sorta cap on it. If i got a high pass filter that matched the same as what is on the 502's tweeters, would that make up the difference?
Post edited by systemcra on
