New PC Case.
fbm211
fbm211 Posts: 1,488
edited August 2010 in DIY, Mods & Tweaks
I swapped cases today.The new NZXT case is a little smaller than the other but everything fit better.
Some of you didnt like the transformer look it has but I do and wait till the two Blue Coolmax 140mm UV Crystal LED Cooling Fans arrive for the top.Gotta get some UV reactive fan filters for the top too.I installed a zalman 120mm front intake that I had in my pc parts box to halp keep the three HDDs cool.These are installed sideways:cool:..And the PS in on the bottom.
I have the blue zalman copper cpu cooler and the window fan is blue so I think I'll go with green fan filters and a red neon inner case light, but not too bright though.
I seem to be still having some cpu thermal problems.One core was getting up to 125F idle:eek: and it used to be 120F --max under load.
I removed to cooler and cleaned it off good and used some thermal grease (zalman) and its still getting up around the same temps.I was out of artic silver so I think its time to order more and reseat the cooler again when I get it.:D
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
