Polk FXi A6 breakin period?
Quick question - I got a set of Polk FXi A6's yesterday .... do they require a break-in period? I'm about to get round to installing them. I should have asked yesterday, but completely forgot.
I already had the center and A9's for a few months.
Post edited by xrapidx on
Yes they do but being surround speakers I would tend to say it won't be as noticable as the others. The rubber needs to be worked to free up.
I would make them the mains for a few days to work them in. Keep them on for a day or so straight. -
Vette C6.r wrote: »Yes they do but being surround speakers I would tend to say it won't be as noticable as the others. The rubber needs to be worked to free up.
Agreed - run them in 2-channel for a few days. They won't be completely broken in.....that takes a few months and a few hundred hours before they really start to loosen up. Caps will burn in too and usually takes a bit longer.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Thanks - quite new at this.
Could I set my receiver to ALL CHANNEL MONO - and run it for a day, getting the same effect? -
Yes..
