Using SDA 2A's and Monitor 10A's in HT?
helipilotdoug
helipilotdoug Posts: 1,229
edited August 2010 in Vintage Speakers
I just got the SDA 2B's I've been waiting for, along with a set of Monitor 10A's. For HT, I'm thinking very seriously about using my SDA 2A's for rear speakers, and the Monitor 10's for the sides. The new 2B's are going through RDO 198/crossover upgrade and will be used for mains once done. Right now I have FXi A5's and A4's for the surrounds and rears, and am thinking about replacing them with the above. What do y'all think about this idea? Thanks, :)
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
Post edited by helipilotdoug on
  • CowboyRJB2
    CowboyRJB2 Posts: 58
    edited July 2010
    I use my SDA 1-Cs as my fronts, and my Monitor 10 series 2 for my rears. And I have the RDO 194 upgrade... I think it sounds outstanding. Remember that in HT, your rears get "EFFECT SOUNDS" and the fronts are FULL LOGIC SOUND in HT.. I think SDA's as rears is defeating the purpose of the Stereo Dimensional Array, itself.
    ELITE VSX-99 REFERENCE
    ELITE PD-65
    SDA-1C's with new RDO194-1 tweeters as MAINS
    MAGNEPAN TYMPANI 1D's for alternate fronts for classical music
    PARADIGM REFERENCE CC-450 Center
    MONITOR SERIES II... M10 REARS
    2 POLK DSW-600PRO SUBS
    "ROCKIN THE HOUSE"
  • Conradicles
    Conradicles Posts: 6,143
    edited July 2010
    Sounds like a killer HT system!
  • mole'
    mole' Posts: 3,160
    edited August 2010
    my new setup will be somewhat like this
    SDA SRS 2.3TL's for the front
    SDA 2B's for the rear
    all with have RDOs and other upgrades in due time.
    mole'
  • bsoko2
    bsoko2 Posts: 1,449
    edited August 2010
    Q: if you are using 2.3TL's as monitors in your home theater and are not usinig the A1 cable, iS it better to have the 4 row woofers to the outside (R&L) or inside (L&R)? If used to the 4 row is on the outside, then the speakers are not in correct order for A1 use. The reason for my asking is that usually the tweets are on the inside and the woofers to the outside.
    Bill
  • mole'
    mole' Posts: 3,160
    edited August 2010
    bsoko2 wrote: »
    Bill
    why are you not using the cable? just dont have one?
    mole'
  • bsoko2
    bsoko2 Posts: 1,449
    edited August 2010
    I quit using it when I had Audyssey with the Integra 9.9 and sold it off as it did interfer with the calibration and freqs. I haven't tried it with the Pio SC-37 that I have now and I wold like to give it another try. I would need a pin/blade cable. Does anyone have one for sale or are their any directions on how to make one?
    Bill
