Money Saver
JimKellyfan
JimKellyfan Posts: 696
edited July 2010 in The Clubhouse
Fans.
We had one attic fan, mushroom style, but have replaced it three times in ten years.
So, I went to the big box store and bought the mac daddy (biggest CFM, thermostat and humidistat ), and mounted it at the end of our ranch home, and above where the AC unit/central unit sits outside ( hopefully helping to move that air too). The internal mounted location, basically, at the top of the triangle shaped vents found on ranch style homes.
It was literally 120 degrees the other day on the attic floor, later creeping up to 140, when I started to work on it. ( many, many breaks as it is too hot to work in 125 and up ). Those temperatures were with the one fan we had. I have heard of hotter attics in my research, and as North as Boston too.
Now, with two attic fans going, and not all the time either now....
Today, going up to clean up, it was 98 degrees.
As long as you have the soffit vents to accommodate the air flow, or increased air flow, it is good to keep the attic just slightly above ambient temperature.
I also followed that up with more "inside the living area" fans, three more, two on the ceiling ( hallway cute little 24 inch fan and an Art Deco funky fan in the LR ) and another portable unit, the Lasko shaped like a tiny square. The Lasko, has plug ins and cost about 50 dollars and when it blew over another unit I was looking at, I knew I had to have that one.
Running a fan is so much cheaper than having your AC unit run all night and day just trying to keep up with the heat of the day.
Hope this helps someone save some money.
I can give more detail to those that want it, model numbers, square footage, whatever...
:cool:
Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar
Post edited by JimKellyfan on
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2010
    That sure is a way to keep the cost of cooling down in the summer.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    VR3 Posts: 28,595
    edited July 2010
    Yep we installed an attic fan in my house middle of last month - energy cost went down 80 bucks THAT month.
    Insanity! ;)
