Blue Ray Player Software
hockeyboy
hockeyboy Posts: 1,428
edited July 2010 in Electronics
So I got a great new computer with a blue ray player but need to get some good software for playing BD disc's. I don't need to rip any blu ray's, but would like something that supports HD audio.
Anybody have experience with this?
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus
(Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
Post edited by hockeyboy on
  • renowilliams
    renowilliams Posts: 920
    edited July 2010
    I use VLC player to play blue ray files but not sure if it works with a player.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • eeagle
    eeagle Posts: 226
    edited July 2010
    I've always used PowerDVD 10 Ultra and it looks like it is still tops in the Reviews. Ultra gets you the Blu-ray capability.
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
  • Janne
    Janne Posts: 139
    edited July 2010
    eeagle wrote: »
    I also use the PowerDVD 10 Ultra. Top program with upscaling and HD Audio.
    HT/2 CH
    McIntosh MX120, MC500, MC206, MEN220
    polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
    MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
  • hockeyboy
    edited July 2010
    Thanks guys, I am going to pick that one up tomorrow then.
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • hockeyboy
    edited July 2010
    Okay I bought it for $71. It's worth it though. Wow what a great picture my computer has! The software is super simple and you can use your mouse if you want to which other brands disabled. Highly recommend. Good advice guys and thanks.:D
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
