Anyone used Dayton cables?
Romo
Romo Posts: 41
Got my receiver, a pair of M70s, and a CS2 so I think it's time to pick up some cables. Does anyone have any experience with Dayton cables? I was going to pick up some SCP-6 from here and wondered if anyone had any experience with them?
I'd be open to other options too, don't have a huge budget for the cables. I was going to grab some from Blue Jeans Cable, but kind of like the look of the Dayton ones, and I don't have to bother terminating them myself.
Alex
  • george daniel
    george daniel Posts: 12,096
    edited July 2010
    A good solid cable in my opinion would be Signal Cable--great solid built cable--IIRC CP members get a 5% discount
    http://www.signalcable.com/analog_interconnects.html
    and if you need a digital cable I have two from BJC you can have one for the small cost of shipping.How's that for a big Club Polk welcome :)
  • acmf74
    acmf74 Posts: 937
    edited July 2010
    I have heard very good reviews on this cable.
    I do have their HDMI cables and they too are a quality piece.
  • jinjuku
    jinjuku Posts: 1,523
    edited July 2010
    You will be fine. I have a 33Ft HDMI cable driving my Projector and it is a quality piece that didn't cost me $400 like a Kimber HDMI that I just saw listed in Audio Advisor:eek:
    heiney9 Posts: 25,715
    edited July 2010
    jinjuku wrote: »
    The OP didn't mention anything about long runs of HDMI cables. Just another opportunity for you to stir the pot about cables, as usual.
    To the OP, I would recommend the Signal Cables as one of the best bang for the buck going, if those are still out of your budget then the Dayton's will do the job for you.
  • acmf74
    acmf74 Posts: 937
    edited July 2010
    when it's time to upgrade I'm definitely going to get the Signal Cable Ultras..
  • Romo
    Romo Posts: 41
    edited July 2010
    heiney9 wrote: »
    I looked at them, still not sure if they're in my price range. For a 6 foot pair bi-wired, it would run me $139. I'd need a good 10-15 feet for the rears, so it sounds expensive. Someone on eBay was selling the Canare 4S11 that Blue Jeans has for $0.99/Ft, which seems like a great deal, but I would have to learn to terminate them myselves.
    Considering I'm only using Monitor 70s/60s/CS2, it seems like spending $140 on cables for the fronts would be a little much?
  • mole'
    mole' Posts: 3,160
    edited July 2010
    Keiko wrote: »
    Funny, I didn't see any mention by the OP about HDMI cables either. Must be a slow day at base camp, B. :rolleyes:
    The Star Quad would be an excellent choice for not a lot of coin, Romo. I'm using the Belden 5000 series for my surrounds and they perform great. Maybe not the prettiest, but I'll take function over form anyday. MonoPrice offers bulk cable also that would work just fine. Terminating raw wire is easy.
    http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10239
    Welcome aboard
    i got my wires from MonoPRICE.com
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=4037&seq=1&format=2
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2817&seq=1&format=2
    cant beat these price
    mole'
  • jinjuku
    edited July 2010
    I simply used it as an example, a representation of the entire line that Parts-Express offers.
    The only people that brought a spoon to this thread is you. Lighten up it was all in good jest.
    Maybe you can pick up one of those $149 usb cables from Audio Adviser. I hear you can hook them up to a B&W laser and it will print color:D
    To the OP: You will be fine with those speaker level cables.
  • jinjuku
    edited July 2010
    Another thing to take a look at slick: Look at the thread title.
    "Anyone use Dayton Cables"
    I do. It's a 33' HDMI cable. I posted what Dayton cable I had. That is was a quality piece and that the OP will be fine with their offerings.
    F1nut Posts: 52,406
    edited July 2010
    I tried some Dayton cables way back when for a little rig in the guest bedroom....quality is not a word I would use to describe them. Didn't sound good either.
    IMO, you'd be far better off springing for the Signal Cables that H9 mentioned.
  • HB27
    HB27 Posts: 1,518
    edited July 2010
    I've tried the Dayton cables also. Wasted my money. IMHO less than average build quality, subdued sound, and not much of a cable.
    Upgrades down the road usually have me wasting my bucks initially.
    Why waste your bucks when you know you'll need to upgrade later.
    Be patient, look around for a quality cable at a good price, and you'll save money. Cheap doesn't mean "money well spent" JMHO again.
  • apphd
    apphd Posts: 1,514
    edited July 2010
    Romo wrote: »
    Depending on what is on the other end of the cables I would agree. But another way to look at it is from HB27's perspective below. If cash is tight, I would go to Monoprice, and wait for another day (and maybe another system) to try some of the better cables. Also check the FM section I think you can usually find some used cables there when you are ready to give it a try.
    HB27 wrote: »
    edited July 2010
    To the OP:
    If you can't justify the Signals (maybe do those for the fronts only) then the Canare 4S11 is a much better choice than the Dayton, even if you leave the ends unterminated.
  • Romo
    Romo Posts: 41
    edited July 2010
    Thanks for the suggestions guys. Based on what I'm reading, I'll stay away from the Dayton cables. I didn't realize what a can of worms I was openening when I asked about speaker cables, I realize this is a bit of a subjective topic.
    I was thinking to go with the Canare wires, really can't beat $0.99/Ft and a buddy of mine who was into car audio for a bit said he'd be able to terminate everything for me pretty easilly. I debated getting some used Audioquest or Kimber cables, but decided against it. This is a pretty modest HT/Music setup, so I think I might stick to something a little more entry level. If I end up upgrading the speakers down the line, or building a solid 2 channel rig, then it may be time to revisit the more expensive cables.
    If anyone has any other reasons why I should go for something better, I'm still open to suggestions. I'm only 20, and this is my first time putting something like this together.
    Alex
    edited July 2010
    Good choice. The Canare is really nice entry level and even a few notches above cable.
  • TORI3
    TORI3 Posts: 234
    edited August 2010
    Good call on the Daytons. I just bought them...and am now having some regrets. For me, they cosmetically looked nice and were terminated with bananas. Because I suffer from paranoia, and also because I have a picky girlfriend, the cables seemed like a reasonable deal. Now that I have them I can say that the build quality is questionable as the plastic before the bananas is loose -- exposing the covered speaker cable.
    In terms of SQ, let's just say that I much prefer my old AQ bare wire setup. This isn't to say that the speaker wire Dayton uses isn't good, but I think their cheap bananas might have an overall negative impact on their product.
    HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
    2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
  • MLZ
    MLZ Posts: 214
    edited August 2010
    Romo wrote: »
    I purchased them for bi-wiring my RTi8's 2 channel system, heard no difference, but left them as is since all it cost me was for more spades at the speaker end.
    If you want to make them pretty just pick up some TechFlex and heat shrink. See http://www.polkaudio.com/forums/showthread.php?t=51988
    I am a klutz, and following the above, including terminating my Canare cables, was a piece of cake
  • HB27
    HB27 Posts: 1,518
    edited August 2010
    I'm probably opening up another can of worms but when you get new cables "IC or Speaker" you'll have to let them burn in for a while before you realize what they'll sound like when they settle in. They will change sound as you play them.
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited August 2010
    HB27 wrote: »
    This might be a stupid question, but what actually happens to a cable during "burn in"? I am assuming there must be a slight change in the cable, else there would be no change in sound. Correct?
  • TORI3
    TORI3 Posts: 234
    edited August 2010
    MLZ wrote: »
    You read my mind about terminating some Canare 4S11 speaker cable. I don't really need to, but making some speaker cable look pro looks like a lot of fun. Here's a great tutorial (with pictures) on DIY cables:
    http://www.avsforum.com/avs-vb/showthread.php?t=776636&highlight=speaker+cable
  • MLZ
    MLZ Posts: 214
    edited August 2010
    One thing I had that helped a lot with the heatshrink was a paint stripper gun, which is like a high temperature hair dryer, instead of using the butane lighter.
  • jinjuku
    edited August 2010
    I'm not sure because:
    1. I haven't had the chance to A/B (sighted or unsighted) cable pulled off the same spool, all terminated the same, with one stereo set being burned in and another not.
    2. Not aware of any peer reviewed scientific papers showing the measurements of a burned in cable vs either a non-burned in cable or the measurements of same cable before and then after burn in.
    It's going to end up contentious any way you look at it. Most sights that have a cable burn in threads usually seem to get locked up. I know Nordost makes cable cookers but I haven't seen anything from them that would stand scientific peer review.
    I guess my question is this: Does Kimber/Signal/MIT/AQ/BJC burn in their cables before they ship them?
    Maybe someone will loan out cable cooker. You could also make your own btw.
    *BTW what sub did you end up going with?
