Mounting a CS2???
i wanna mount my CS2 above my TV that is hanging above my fireplace. i dont have room below the TV, so i have to mount it above.
anyine have any ideas or know of a special mounting bracket for the CS2?
thanks
thanks
mole'
Post edited by mole' on
I built a shelf above my TV(make sure you screw into the studs). My CS2 and DVD player and Xbox360 are all on it. Deuce
i was hoping not to have to make something.
post a pic of yours if you will?mole' -
I have a DLP, and have the CSi5 above it. I'm using the Omnimount Set Top Component Shelf to accomplish this. Not sure if it will work for an LCD, but the legs offer various lengths and positions that make it a pretty sturdy.
Pictures of the shelf, from the side, can be seen here:
http://www.polkaudio.com/forums/showthread.php?p=1033140
If that won't work, they might have another solution for you.
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
The omnimount listed above wouldn't work for me since my TV is too thin.
This is what I use:
http://www.pinpointmounts.com/am15.html
You can find it for 30 bucks shipped online. It feels quite sturdy when screwed into studs, I believe it's advertised to hold 30 or 35 pounds which would accomidate the CS2.
Edit: I also shyed away from the omnimount since some reviews I found of it said that it colapsed under the weight of a center speaker after time. -
I would put a shelf into some studs on a downward slope and put something on the front lip to stop it from sliding forward. This way its sturdy, and also points down at the listening position.
Scott
that looks sick in your pics. it wont work for me that. my TV is only 2" thick. thanks tho man.mole' -
This is what I use:
i think these will do the job for me. nice find and THANKS!!mole' -
grimmace19 wrote: »I would put a shelf into some studs on a downward slope and put something on the front lip to stop it from sliding forward. This way its sturdy, and also points down at the listening position.
i was thinking about doing that. but i think im gonna use the L Shape brackets from the post above.mole' -
It took me forever to find something like these -- for a long while I considered building something myself, but I was happy to find these. -
If you did make room underneath, the CS2 does sit downside up and tip up.Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
JimKellyfan wrote: »If you did make room underneath, the CS2 does sit downside up and tip up.
i only have 4" under my TV. i had a small RM7cc there but it was too small compared to my other speakers.mole' -
found these mounts
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082804&p_id=6839&seq=1&format=2
think im gonna use one for my CS2 and some to mount my Monitor 40s as Surround soundmole'
