Grilling Steaks
Disc Jockey
When I had a cheap grill, it was easy to put a crust on steaks and still get them good and rare because my grill would flare up if I looked at it crosswise. With my Weber, although it is great with just about everything else, it wouldn't crust a steak properly.
Tonight I tried a method which goes against about everything I have learned about grilling a steak but it was, in a word, spectacular. A nice crust and still cool in the center - just like a good piece of cow should be.
Here's the link: http://www.cookscountry.com/recipe.asp?recipeids=5591&bdc=67092
Try it, you just may like it
"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
Post edited by Disc Jockey on
Our favorite way for steaks is to of course buy close to when you want to eat them, buy carefully when on sale, but the main thing....
Use the food saver combined with either Spiedie sauce or a homemade version.
Homemade version is just a super Italian dressing really.
Put individual steaks in the food saver bag with a bunch of your sauce and the food saver process opens the pores of the meat to take in the moisture.
Then, pop it in the freezer, at least for an hour, more if you want better, overnight at the longest, but even a week later is fine if frozen, of course.
MmmOnkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
Next time, you may want to add a little bit of honey to the outside of the steak or in your rub/marinade. It will caramelize and give you the same result.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
That would be hard to do but it makes sense. I'll give it a shot next time I grill up a steak just for me. Thanks for the tip.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505 -
Now, I must have steaks tonight.Onkyo TX-NR636
Audio Outdoors
Shed
Shed 2
that does go beyond everything we've been taught about grillin meats. i've always heard that you want you steaks at room temp. so the meat and fat relaxes, and flavors and juices the meat.
I marinate mine in soy sauce and finely chopped garlic with pepper. i dry them off before putting on grill.. the soy sauce to me if just the right amount of salt and it seems to marinate deep into the steak. no more salt is needed if you use soy sauce.
I marinate them for an hour + in soy mixture. then throw them a hot 450 degree grill, then sear each side for about 3 or 4 mins, then turn temp down as low as it will go.. about 200 degrees and continue cooking till done.. about another 10 to 15 minutes at this very low temp.
remove and let rest for 10 minutes, then slice and enjoy! placed inside a warm tortilla, with cilantro, pico de gallo, and sliced avacados and eat them suckers up. So good.PolkFest 2012, who's going>?
Although it goes against what feels right to me I find I get a better flavor when I leave the lid open.Vinyl, the final frontier...
danger boy wrote: »that does go beyond everything we've been taught about grillin meats. i've always heard that you want you steaks at room temp. so the meat and fat relaxes, and flavors and juices the meat.
so good that way
i have to have my steak well done.mole' -
Searing the meat is critical, keeps the juices in. Turn grill up to max temp and place steak on grill for no more than 2 min per side, then grill to desired temp. I like mine rare so it is a short time for me. I used to be a chef believe it or not. 7 course restaurant.
You guys have me drooling like a an overworked dog!
I'm firing up my grill now.
Thanks -
Disc Jockey wrote: »When I had a cheap grill, it was easy to put a crust on steaks and still get them good and rare because my grill would flare up if I looked at it crosswise. With my Weber, although it is great with just about everything else, it wouldn't crust a steak properly.
How hot do you get your grill up to before placing the steak in? I like to get at least 600 degree but sometimes that's just too high when the cut is not thick enough.Main Gear
Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7. -
back in the day when I was working my way through college, I spent a lot of times in the kitchens of restaurants. One of the tricks I learned was how to do a good butter broil or what some would call an eastern rare.
The grill needs to be Hot! 500 minimum. (550F to 600F is where we had our main cooking section of the broiler set). The steak needs to be of a decent thickness 1" or so. Generally, the steak should be at room temperature, but if you want it cooler in the center and the steak is thinner it is OK to have it refrigerated.
Pat the steak dry with a paper towel and apply seasoning. Place the steak on the grill and let it sear for about 30 seconds or so. Throw clarified butter onto steak and the grill. The resulting flames, will sear the steak. Move the steak to mark it (diamonds for strips squares for Tbones / Porterhouse / Filets). Flare the steak again with the clarified butter. Turn the steak and flare it one more time.
Pull it off and you should have a perfect butter broil / eastern rare. Fully seared, juicy and cool in the center. The flaming butter also helps add some of that char broil flavor to the steak.
I should also mention, I haven't tried this with a charcoal grill. It should work the same, but I don't know if charcoal ash would coat the steaks.
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
Thats it!!! I am going to buy a sirloin tonight and cook it to perfection. I am thinking Merlot to go with it
I'm heading out to Ruth Chris right now for a bone in rib-eye. Bringing my own wine too, a nice Duckhorn cab.HT SYSTEM-
lsi 9's -
I get it up to about 600 also but you do have to watch the cooking time with thin steaks. A couple of minutes per side is about all I do for a 1 1/2"-2" steak. The best kind of fast food"The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Mike Kozak wrote: »Thats it!!! I am going to buy a sirloin tonight and cook it to perfection. I am thinking Merlot to go with it
A nice big Cab or Zin would be better"The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Disc Jockey wrote: »A nice big Cab or Zin would be better
+1 MMMmmm....a nice deep spicey Zin w/ a seared and peppery steak- perfect combo.
up your budget and go with a more tender cut of meat.. sirloin is usually not the most tender cut.
New York or T-bone or rib eye will be much better cuts.PolkFest 2012, who's going>?
danger boy wrote: »up your budget and go with a more tender cut of meat.. sirloin is usually not the most tender cut.
Yeppers, do it right"The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Unless......you are a Costco member and your store is selling USDA Prime grade sirloins, NY strips and ribeyes. Those sirloins can almost be "cut with a spoon" ! $5.99/lb. for sirloin !:D -
True dat.
I'd put a top sirloin from my local speciality meat shop up against a Costco NY any day.
But, all other things being equal - a dry aged Prime rib-eye cooked just right is to die for....
