Where do I plug wire from laptop to receiver
kprhok
kprhok Posts: 42
I am running an RCA wire from my laptop headphone jack to my receiver, but I am uncertain about where the jack (two plugs) will plug into my receiver.
I have a Harman Kardon 3490 with CD inputs, Tape/CDR Inputs, Phono inputs and various video input slots.
I will have a CD "jukebox" and Phono, so should I use the "Tape/CDR Input" slot
I want to play iTunes from my laptop.
Thanks for your input!
k
  • hagmanm2
    hagmanm2 Posts: 205
    edited July 2010
    Yup, you can use any input (besides the phono) regardless of it's 'intended labeling.' Enjoy!
    Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
    Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600
  • kprhok
    kprhok Posts: 42
    edited July 2010
    I could even use the video plug-in slots?? There are several of those...
    tx.
  • Willow
    Willow Posts: 11,370
    edited July 2010
    kprhok wrote: »
    tx.
    You can use the audio portion of the video input. You cannot plug it into the actual video plugs.
  • SivaNevets
    SivaNevets Posts: 303
    edited July 2010
    theres a behringer usb mobile usb sound card for around $30, that includes optical/phono and RCA out. i bought it as a gift for my frd, very vauble for the money
    http://www.amazon.com/Behringer-UCA222-U-Control-Ultra-Low-Interface/dp/B0023BYDHK/ref=sr_1_fkmr0_1?ie=UTF8&qid=1279906733&sr=8-1-fkmr0
    the white one is with phono
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • fishbones
    fishbones Posts: 947
    edited July 2010
    I recently went through this and used this (instead of headphone jack/rca due to computer hiss and terrible SQ through the computer): http://www.turtlebeach.com/products/sound-cards/audio-advantage-micro-ii/gclid/cizaovx6wkicfqu-sgodt35h6q.aspx
    Then I got this: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022901&p_id=2763&seq=1&format=2
    I checked, and you have and optical-in jack in the back of your H/K. Waaaaay better sound than using rca's (I tried the rca from headphone jack first, and it sounded AWFUL!). I needed something reasonable as the first attempt at using the computer as a source, and it worked like a charm. BTW, the toslink cable from Monoprice is an unbelievable build quality - looks like a $100 cable (though I'm sure it doesn't sound like one).
    The Turtle Beach can also be used as a headphone output (sound is night and day difference from the cheap headphone out jack supplied with the computer).
    This is my first post...
    Good luck
  • kprhok
    kprhok Posts: 42
    edited July 2010
    Thanks, all, very good information. I'll check out the links!
