Wire gauge used in SDAs
fbm211
fbm211 Posts: 1,488
edited July 2010 in Vintage Speakers
Could someone please tell me what gauge wire is used in the SDA2Bs.? I need to get some and would like to know what to order.--Cardas 15.5 ???
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • Bubinga99
    Bubinga99 Posts: 283
    edited July 2010
    It will be printed or embossed on the wire insulation, about every foot or so. Not always easy to see.
    For 2.3TLs it's 16 gauge, so I imagine they used that in bulk.
    F1nut Posts: 50,757
    edited July 2010
    Yep, 16 gauge.
    Warning, the Cardas chassis wire, while great stuff, is extremely difficult to solder unless you have a solder pot.
  • Face
    Face Posts: 14,340
    edited July 2010
    It can be done with a hot iron if you're willing to strip the ends and use a dremel to polish off the coating off the individual strands. Regardless, PITA.
  • Bobsama
    Bobsama Posts: 526
    edited July 2010
    IIRC, Cardas is not recommended for internal wiring as the stuff's too tough to solder and isn't flexible.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • Face
    Face Posts: 14,340
    edited July 2010
    It works fine for internal wiring as long as you can deal with terminating it. As far as flexibility goes, it's a little less pliable than lamp cord and much easier to work with than solid core.
  • Bobsama
    Bobsama Posts: 526
    edited July 2010
    Face wrote: »
    I was probably thinking of solid-core wire then.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    What would be a good alternative.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Would this vampire wire work.?Doubled up.
    http://www.vampirewire.com/pc-121-37-c-18-red.aspx
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    I think I have a solution
    I like there power cord wire and plugs.I should like this.I still need to solve the molex connector problem guys.Does polk have any of those 3wire plugs for the binding post to xover????
    The wire I will try-- http://www.partsconnexion.com/wire_hookup_furutech.html
    F1nut Posts: 50,757
    edited July 2010
    The Furutech wire should be fine.
    For Molex connectors, www.mouser.com
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Finally...Thank You F1.
    Now to try and find a match.Hopefully I wont have to replace the one on the xover.
    Toolfan66 Posts: 17,337
    edited July 2010
    Is there really a sonic difference in changing the internal wires?? It seems that some say yes some say no.. But my guess is it really depends on what you are running your speakers with.. if your amp,pre and source are just on the lower end you may not hear any difference. This might be true for most tweeks. But what the hell do I know? I'm still a noob when it comes to some things....LOL
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • Face
    Face Posts: 14,340
    edited July 2010
    How about, it depends. :D
    Depending on the wire used, etc... But I can't see why it couldn't make a difference on SDA"s due to the length of wire used.
    And if you're using quick disconnects on the drivers, why not solder the cables directly to the board?
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    I hope to find out soon if my gear is good enough to hear a difference.It better be a damn good increase in SQ,...Have you seen how much the furutech alpha wire goes for.? Not sure if a 100+ is overpaying for this type of tweak.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Face wrote: »
    I have no problem with the drivers cables to the boards and in fact one xover came with the mids wires soldered to the board.
    Its the Binding posts direct to the board I dont want to have to do yet.
  • Face
    Face Posts: 14,340
    edited July 2010
    Yeah, I can see that being a PITA if you need to remove the crossover. There are other ways around it though, quick disconnects, etc...
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    I was thinking of using male and female disconnects.Id like to find some good copper ones though
