Preamplifier
mole'
mole' Posts: 3,160
edited July 2010 in Wanted (WTB) Classifieds
im looking to buy a Pre Amp to match my current setup in my sig. thanks
mole'
Post edited by mole' on
  • SivaNevets
    SivaNevets Posts: 303
    edited July 2010
    your current receiver will be excellent for HT use, i would suggest you to invest that extra money for the best sub you can afford. im talking about something like DSW Micropro 4000 or some SVS sub..
    pswi225 is mediocre
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • mole'
    mole' Posts: 3,160
    edited July 2010
    ya my current PSWi225 is not doing its job.
    i was looking at the PSW505 and the microPRO 2000
    i picked up the Adcom amp but dont have the Pre out on the back of my Denon AVR.
    mole'
  • SivaNevets
    edited July 2010
    micropro 2000 is excellent for music, when comes to HT, a bigger sub is better.
    try not get the psw505, dsw pro 600 is much better if micropro4000 is out of ur budget.
    the dsw line up is much better than psw overall.
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • mole'
    mole' Posts: 3,160
    edited July 2010
    the microPRO is a tad out of my budget right now. i wanna get the rest of the system together first.
    thanks for the input man
    mole'
  • mole'
    mole' Posts: 3,160
    edited July 2010
    stuff i found.
    Adcom GFP-555 II Preamp for under $150
    B&K AVP1030 Preamp for $200
    B&K Reference 10 PreAmp for $200
    B&K Pro-5 Pre-amp for under $150
    Denon PMA 700V Preamp for under $150
    mole'
  • PSOVLSK
    PSOVLSK Posts: 5,397
    edited July 2010
    mole' wrote: »
    I own this one and I really like it. I run mine as a pre- in my 2-channel setup with LSi-15's. This may not matter to you, but it also has a non-powered Zone 2 option.
    You probably can't go wrong with any of the one's you've listed.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    i was thinking the Adcom cause it would match my Amp, but that B&K does look nice........
    mole'
  • DollarDave
    DollarDave Posts: 2,575
    edited July 2010
    A couple of us have B&K pre amps and I think we have all stuck with them for a while now. I have mine mated with a NAD C270 amp and a pair of SDA CRS+'s and it works out real well.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    im thinking about picking up both the Adcom GFP-555 II Preamp for under $150 and B&K Reference 10 PreAmp for $200. see which one o like best and sell the other one.
    this is a pic of my current Adcom Amp with the Adcom Pre amp im looking at getting
    i like the matching look....
    http://www.audio-teams.com/webboard/img-lib/webboard/wbp_112680384651.JPG
    mole'
