Where do you cross your RTI's?
Just hooked up a new pair of A7's and lovin' em a LOT!
But I'm curious about those with RTI's and X.1 systems, where do you cross them over to the sub? I used to cross my TSI500's at 80 but I've initially set the RTI's at 60 with the center CSi A6 set at 80Hz. I'm using a PSW505 sub.
How about any of you?
Fronts: Polk RTi A7's
Center: Polk CSi A6
Surrounds: Polk TSi500's
Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
Amplifier: Emotiva XPA-5
Processor/AVR: Emotiva UMC-1
DAC: Emotiva XDA-1
CD player:Emotiva ERC-1
Blu-Ray: Oppo BDP-93
Turntable: Kenwood KD-500
Tonearm: Polk-Mayware Formula 4
Cartridge: Shure M97-XE
Television: Sony KDL-55EX500
Center: Polk CSi A6
DAC: Emotiva XDA-1
Post edited by geebolt on
I cross mine at 80 (RTi10s... predecessors of the RTiA7s). I fooled around with 40 and 60... Couldn't tell too much difference with most HT material.
I cross them at 60 and the CSi A6 at 60 as well. I run them at full (large) for music and multi-channel music.
Play around with it and see what works for you. Goodluck -
You can try it at any point, but if you have the juice to run them large and cross the LFE over at 80, then you'll hear a difference. The bass won't be re-directed from the mains and the sub will have less output, but you'll gain a full range sound from the A7s and you might appreciate it. Running the speakers small and cutting at 60 or 80 might make a difference depending on which blends better too. Crossing them at 40 takes too much info from the LFE channel.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I just trie crossing everythin at 40 and preferred the previous 60/80/80. Still haven't tried running full range yet, but definitely will.
GeorgeFronts: Polk RTi A7's
Center: Polk CSi A6
DAC: Emotiva XDA-1
