5.1 inputs
conqur
im running 5.1 inputs from reciever to my bluray player. the volume is lower on the sound then using the coaxial or optical. also what am i supposed to set my player to bitstream or pcm. thanks in advance for any help.
Post edited by conqur on
Set your player to 5 ch analog out. Crank the subwoofer up 6 to 10 db in your AVR's menu. Life will be good.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
When using 5.1 analog outputs from a player, the player is doing the processing, instead of the receiver. So, you need to set speaker distances and levels in the player's setup menus, like they are in your receiver's. This is why the volume is lower than when using the optical or coax (the settings are different).
Depending on the wording your player uses, you may have to set the priority to 5.1 analog out (or multi-channel), instead of HDMI or Optical. For the HD audio you may have to set it to output PCM or LPCM, depending............
Good luck!Samsung HL61A750 LED DLP
Onkyo TX-SR805 receiver
Oppo BDP-83 blu ray player
Polk Audio LSi9 front speakers
Polk Audio LSiC center speaker
Sony SS-MB100H rear speakers
SVS PC12-NSD powered subwoofer
Pioneer PL-514 turntable
Logitech Harmony 628 Universal Remote
