Any Idea?
snow
snow Posts: 4,358
edited July 2010 in Speakers
Would any of you care to venture a guess on what this may consist of?
http://fairbanks.craigslist.org/ele/1847345754.html
the only clues regarding the speakers is that the sub woofer has two 10" drivers and is rated at 300 watts. The receiver was easy to look up. I emailed this guy asking the model numbers and his response was their Polk audio and would I like to look at them, I replied back yes I would.
well I figured that out from your ad dumbass thats why I emailed you :rolleyes:
REGARDS SNOW
Post edited by snow on
  • Conradicles
    Conradicles Posts: 6,401
    edited July 2010
    The sub could be the 650 or 1000...
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited July 2010
    usually you can check what you can get at the local Best Buy. He's got monster cable and a low end HK receiver... tsi's maybe???
  • snow
    snow Posts: 4,358
    edited July 2010
    Well he called me its a RM-7500 system should I go for it or pass?
    REGARDS SNOW
  • cokewithvanilla
    edited July 2010
    If it were me, I'd pass. Kinda like a "what would I use this for" sort of thing...
  • snow
    snow Posts: 4,358
    edited July 2010
    Agreed :)
    REGARDS SNOW
