Please help me set up my Micropro 2000
dhart86
dhart86 Posts: 1,594
What's up Polksters..........I got my MP2k about a week ago, I have read the similar threads on this forum, but I still am not able to get the sub to respond. I am having that "I can't tell if its on" thing. I'm using it for a 2.1 (music) rig.
My room my be the culprit. It's an oddly shaped finished basement. Easiest room description would be to say it is 25 x 27, but actually the front 2/3 of the room is actually 22'w and the back 1/3 is 27'w
Is my room to big for this sub? My listening position is about 14'
I have a SPL meter and avia (test tones), but have no clue as to what I am looking to do with them.
I am NOT smarter than a 5th grader, so can somebody tell me step by step what I am looking to do with SPL / test tones? Sub is connected to a 2 ch pre thru the line level connects
Please advise......thanks
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2010
    dhart86 wrote: »
    What preamp do you have?
    When you say you can't get your sub to 'respond' - does that mean if you put your ear up to it when playing music you don't hear anything?
    Is the sub light 'on' indicating it is receiving a signal?
    What frequency do you have the xover set to on the back?
    Not to sound rude, but have you verified that the pre is connected to the line level 'inputs' and not the 'outputs' on the MP2K?
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited July 2010
    Also, have you run the auto-setup with the microphone, to first ensure that it's functional? Once activated, it should immediately begin with a series of test tones that are quite loud.
  • dhart86
    edited July 2010
    Erik Tracy wrote: »
    Erik the sub is on...I can hear it slightly when I put my ear to it. I have volume set to 30 out of 40. Pre-amp is Rotel 1070. XO frequency is set to 60. The problem is, the sub is on but I have to be right on top of it to hear it. Thanks for your reply
    Main Rig:
    Second Rig:
  • dhart86
    edited July 2010
    mdaudioguy wrote: »
    Audioguy...ran test tones Ok
    Main Rig:
    Second Rig:
  • mdaudioguy
    edited July 2010
    dhart86 wrote: »
    I have found it difficult to judge the output of a sub by putting my ear up to it. Tweeters and mids, yes, but sub frequencies just don't seem conducive to that kind of inspection. I hope that makes sense. Also, a properly setup sub can often be subtle, depending on the material you're asking it to play. Make sure your source material has prominent bass below 60Hz.
    Another thought - The sub has a remote... try turning it on and off while playing some music that has a fair amount of bass.
    Also, what are your main speakers? Perhaps they're capable of playing low enough themselves that they're obscuring your sub. Remember, the crossover adjustment only effects where the sub cuts in, not where your main speakers cut off. There may or may not be significant overlap.
  • dhart86
    edited July 2010
    mdaudioguy wrote: »
    Thanks audioguy ...my mains are the LSi7's...
    I will try turning sub off/on w/ remote....I didn't know that the crossover settings worked that way. I used to think that it was the point were the mains cutoff and the sub cut in. Thanks for that insight, it gives me a better idea of what I should be expecting from my sub.
    Do you think my room size is too big for the 8" sub?
    Main Rig:
    Second Rig:
  • mdaudioguy
    edited July 2010
    I was running one in a 25 x 18 room and it was adequate (I think many people would have been satisfied)... 2 are better. ;) It should be providing an acceptable amount of low end below what the 7s are capable of on their own.
