Watts and Ohms
swb502
swb502 Posts: 112
Hello All!
Its been a long time since physics 101 and I need some help with the relationship between amp and speaker. I was using this site to try and help myself along but it hasn’t really answered my question directly:
http://www.bcae1.com/spkrmlti.htm
If I have say 2 Polk Lsi9 speakers, with 4 ohms, and wire them in series, that puts both at 8 ohms. So say I have a Emotiva xpa-1 that is rated at 500 watts per channel at 8 ohm and put those two Lsi9s on it. Is each speaker getting 250 watts then? Will the speakers or the amp be destroyed or is this within tolerances? Will the sound in both speakers get distorted because of the extra load?
Thanks for all the help!
Work in Progress HT
Receiver- Yamaha RX-2700
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2 x 2
Surrounds- Polk Audio Monitor 70
Rear: Polk Audio Monitor 40
Sub- Polk Audio PSW505 x 2
Projector: Epson 8100 HC
Screen: Visual Apex 120"
Blu-Ray- 60 GB PS3
  • TNRabbit
    TNRabbit Posts: 2,168
    edited July 2010
    What you are saying is correct. Each speaker COULD get up to 250 watts, all things being equal. Doesn't mean you have to run them at the ragged edge, though...
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited July 2010
    swb502 wrote: »
    Hello All!
    Yes, your power should be fairly distributed between the 2 speakers. However, with speakers you are talking impedance not resistance and it reacts differently at various frequencies ideally, you should demo and see if the end results pleases you. As far as the amp, no risk of damage as long as you hook-up in series not in paralell.
    By the way, welcome to CP swb502 :)
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
