Guy Stuff thread: Concrete Polishing
concealer404
Has anyone done this? Anyone have any cool DIY guides?
Tips, tricks, or tell me to run away screaming?
Assume 1000+sq ft. Is this something that will make me wish i was dead if i tackle it? Seems a pro would charge $3-$6/sq ft. I'm not cool with that.
Post edited by concealer404 on
amazing what google finds for you
http://www.ehow.com/way_5180367_do-yourself-concrete-floor-grinding.html
PaulyLife without music would♭ -
I think for a DIY'er, it would be easier to clean it with muriatic acid, then put down one of those epoxy coats that are smooth and shiny.
Is this for a garage, or indoor area?For rig details, see my profile. Nothing here anymore... -
I already read that one.
Looking to be spoon fed to know what to watch out for so i don't screw up badly.
Has anyone actually done this? Or paid someone to do it? (If you paid someone, what was the rate?)I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Looked into that, but can't verify yet if said 1000 sq ft of concrete has a moisture barrier or not. If it doesn't, epoxy will be a futile effort and a waste of time/money.
My other concern is that from what i've seen, although it may have been due to crappy prep jobs, is that the coatings tend to chip or de-laminate when heavy objects are dropped on them, or when heavy things on casters roll over them.
Plus polished looks awesome!
I guess on the flip side, it's a garage floor, so who cares?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
My grandfather does this stuff, I gave him a call and he says its always a good thing to put a coat on concrete he said it lengthens the life of it by quite a bit. He said that he usually does touch up jobs every few years to keep it coated well. If you live in a moist area with lots of weather shifts it may be a good idea.
I didn't have a chance to ask him of any tricks since he has to go away for a few days so maybe he will tell me when he gets back.Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
PerfectCreature wrote: »My grandfather does this stuff, I gave him a call and he says its always a good thing to put a coat on concrete he said it lengthens the life of it by quite a bit. He said that he usually does touch up jobs every few years to keep it coated well. If you live in a moist area with lots of weather shifts it may be a good idea.
Thanks!
But... i'm not really asking about coating. I know how to do that.
I'm talking polishing... or "sanding" as some may call it. Use discs to sand/smooth it to a finish.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I don't know what he uses....I would imagine you could use like a buffer disc? I think that may have been what we used when we did our garage when I still lived at the house....
It was kind of like the ones that you can use to wax a floor with but much bigger....
I honestly do not remember it was some time ago...at least a 4 or 5 years since then.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
When you get it done. Give me call. I'll come over and do a big nasty burnout in it to break it in.;)
Nik -
Head over to http://www.garagejournal.com/forum/ and post this thread in the flooring section. Or just poke around over there.Ludicrous gibs!
nikolas812 wrote: »When you get it done. Give me call. I'll come over and do a big nasty burnout in it to break it in.;)
Nik
Hey!!!!!!
PM coming your way.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Oh cool! Yeah, i'll browse around there, thanks Noah!I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
You could also post your question on the Fine Homebuilding and Journal of Light Construction sites and get some feedback. To polish concrete countertops I use 3M Trimite wet/dry sandpaper, starting with 120 grit and working up to 220 grit, using enough water to get a good slurry worked up. The mix I use for concrete countertops is much different than the 2000 to 4000 psi mix that should of been used for a garage floor.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
only thing I ever did was have to power wash concerte sidewalks and crap when I was a lifeguard early in the morning. PITA I thought. Good luck!
Not trying to be a dream stomper here and prevent you from being as manly as possible but considering that you talk about working on your cars a lot and you say its a garage floor, I am having thoughts of a incredibly slick surface then you spilling some oil or something similar on it and you then busting your arse.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all -
REGARDS SNOW
LOL!
Good point, though. After looking at costs to rent the machinery and everything, it's probably just simpler, and way cheaper to just leave it as raw concrete, and just powerwash it every few months.
Raw concrete is manly, anyways.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »LOL!
Raw concrete is manly, anyways. ;)
and I'm sure you'll be out there in a neon pink shirt with neon green pants singing to some golden oldies.....
acutally when I saw it say Guy stuff and Polishing something...i got the wrong idea of what was going on...:eek: -
Well... there WILL be a lot of work done to a Celica... which we all know is a "girl's car."I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
REGARDS SNOW -
You are correct. The guys who did the concrete in my garage didn't even do a full polish, but it's still very smooth, and also very slippery whenever it gets wet. Which is all winter, with the snow melting off the cars.
Alright, that sinks it, even though it's not THAT kind of garage. I appreciate the anecdote.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
