My new 7 Channel PA for Lsi Speakers
jmos
Gday everyone, I have been on a bit of journey to improve the sound quality on my Lsi system and interested in your point of view.
I have Lsi15's, LsiC and four LsiFX speakers.
I started off with an Onkyo 875, than purchased a NAD T973, 7x140@8ohms, 7x280@4ohms but I still felt I was missing something.
I have just ordered a new 7 channel PA and it should arrive next week, just wondering what you think of the specs, I guess I should have asked this before I ordered but I got a great deal and had a credit with the store.
I am using HT bypass on my Cambridge Audio 840A for 2 channel listening.
The specs and description are as follows, its an Ozi made product, its a new model. The previous model was very popular here in Australia.
Elektra Theatron HD 7 Channel Power Amplifier
The NEW Elektra Theatron HD is a high performance 7 Channel power amplifier designed specifically for both Stereo Music and Home Theatre Audio reproduction.
The power supply plays a significant part sound quality. Starting with our transformers we use extensive electrical and magnetic shielding to keep radiated interference out. Along with this the transformer is potted in encapsulation to eliminate all mechanical vibrations. Our power supply capacitor are premium Audio Grade Nichicon capacitors which are selected for two reasons audio performance and reliability.
To eliminate the loading effects on preamps and Home Theatre Processors the input stage of the amplifier uses a matched JFET which have very high input impedance.
The signal path is direct coupled meaning there are no capacitors to degrade the sound quality.
The amplifier topology is unique in that the signal amplification is realised in the current domain and this achieves both excellent linearity and has greater immunity to power supply noise (PSSR) resulting in greater musical transparency and excellence in tonality.
The power output transistors are Ring Emitter Transistors (RET) and these devices have a 60Mhz bandwidth and lower distortion and this results excellent sound because they can produce a balanced sound across the audio range with tremendous amounts of power.
Massive 1800 watt power supply insures that each channel receives the appropriate voltage and current at all times, regardless of input signal or speaker load.
Each channel can deliver its rated 200 Watts into 8 ohms and a peak power of 400 watts into 2 ohms to assure tremendous dynamic headroom for life-like soundtracks and special effect passages.
Specifications
Power per Channel (Watts RMS)
8 ohms 200W
4 ohms 380W
Total Harmonic Distortion 0.005% into 8ohms
Dynamic Power (Watts RMS) 2 Ohms 400W/ch
Frequency Response 3Hz - 250 kHz. +0,-3 dB
S/N Ratio 112 dB
Input Sensitivity / Impedance 1.5 V / 270 k
12V trigger
The amplifier will trigger off 12V trigger
Transformer 1.8KVA
Discrete Power Amplifier Circuitry
Balanced Inputs
Banana Plug Compatible Speaker Connectors
Height: 160 mm, Width 445 mm, Depth 370 mm,
Weight: 27 kg
Specifications
8 ohms 200W
4 ohms 380W
S/N Ratio 112 dB
12V trigger
Transformer 1.8KVA
Balanced Inputs
Weight: 27 kg
Post edited by jmos on
pics or it didn't happen...
If you could pop the top and take a couple of the insides, that would be awesome.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Looks like a beast and it should wake up your LSI's beautifully. Congrats & enjoy.
http://clefhifi.com.au/catalog/product_info.php?products_id=70Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Thanks cfrizz, I should have posted the link appreciate it.
Its only just been released but no doubt pics of inside should be available soon.
Waking up seems to be what my Lsi's seem to need and I am really hoping this amp will do it.
Let us know how it sounds
HT and Music Rig
Receiver- NAD T765 HD
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Surrounds side- Polk Audio Monitor 60
Sub- Polk Audio PSW505
Windows 7 Media Center
T.V.- 40" Sony Bravia LCD 1080P
Blu-Ray- 80 GB PS3
